Question about Wine & Spirits
I have a bottle of white rum at home. How can I turn it into spiced rum?
Posted by jack on
roger nori
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 33 Answers
Begin by pouring your rum into an air-tight container (perhaps a mason jar). Then add a selection of your favorite herbs and spices and let the mixture sit for a while. Which herbs/spices you choose are up to you; however my personal favorite combinations are orange peel, cinnamon sticks, cloves, nutmeg, ginger and peppercorns.
Posted on Feb 03, 2013
Bizhub350 toner not feeding
Power off the machine. Then remove the toner bottle, be careful the hole might be on the bottom and the toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner bottle correctly. If THE KNUB on the side of the bottle is damage put a new one in. That KNUB is what the toner motor uses to turn the bottle, if it damaged you get a code. If that does not work, you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Mar 05, 2017 | Minolta bizhub 350 Black and White Copier
Is it possible to infuse liquor with other flavors?
Absolutely! Vodka is the most common, but you can also infuse gin and white rum if you would like. I found a great website with plenty of advice on what to use and how to accomplish it. Hope it helps.
http://drinks.seriouseats.com/2012/05/diy-vs-buy-how-to-infuse-spirits-at-home-flavored-vodka-or-rum.html
Feb 05, 2013 | Wine & Spirits
How are both white and dark rums aged?
white rum is aged in either a metal or plain oak container; whereas dark rums are aged in charred oak barrels, helping give the liquid their finished color. Aged rum picks up flavors from the barrels they are aged in, similar to whiskeys
Feb 03, 2013 | Wine & Spirits
What is coconut rum?
Coconut rum is simply white rum flavored with coconut extract. It is often used in cocktails, most commonly mixed with pineapple juice. One of the most popular brands of coconut rum is Malibu.
Konica minolta 363 error message c-2201
Power off the machine. Then remove the toner bottle be careful the hole might be on the bottom toner is going to go everywhere. Then close the toner cover and turn on the machine. Let the machine go through it normal routine. When it asks for toner install the toner correctly. If THE KUNB on the side of the bottle is damage put a new one in that KUNB is what the toner motor uses to turn the bottle if it is damaged you get a code. If that does not work you might have a bad motor or the home sensor or actuator for the toner bottle is bad worse case the control board is bad
Feb 24, 2012 | Minolta bizhub 350 Black and White Copier
Spice 4242 white display
www.mygsmindia.com/.../spice.../60966-spice-5151-white-display-s... clilk the link your problem solved
Sep 17, 2011 | Cell Phones
New toner cartridge won't insert all the way
Is this a genuine toner cartridge if it is then the home position unit inside were the bottle goes is not in the correct position . You can try turning of the machine power it down then wait about ten seconds and power the machine back on when it asks for the tonet bottle try putting the bottle in remember do not force the bottle in if this dose not resolve your problem you will need to call for a certified technician
Jan 31, 2011 | Kyocera Copystar CS-1620 Black and White...
Default password for spice mobile model M4580 FOR INCOMING CALLS
spice m-4580 phone incomingcall onering and phone will be buse
Dec 08, 2010 | Cell Phones
Toner bottle does not turn to add toner
is the toner the Correct toner. If it is wrong the bottle will not Mesh with the motor
Apr 01, 2009 | Panasonic FP-7750 Black and White Copier
Wine & Spirits Logo
222 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
