My laptop is not shuttig down, monitor gone blank but I can see the screen writing.
SOURCE: dell inspiron 5150 dark screen, faint image in background
ah, change the backlight it is most likely dieing
-CG
SOURCE: Dell inspiron 1300 back light problem
All laptops have a backlight and an inverter to power it, and the problem you have is very common. Usually replacing the inverter board in the display fixes the trouble. There are a number of vendors online offering replacement parts. Here is one that just popped up after a Google search. You can also find videos on youtube showing the procedure for opening up the display to install the new part. It's a simple process that most people can handle with a little patience and some small tools.
It's also possible the light itself has gone bad, but the inverter failure is more common. The backlight on some displays is not replaceable separately. So try the less expensive inverter replacement first.
SOURCE: Dell Inspiron 1501 laptop screen will not work.
If you hear the hard drive spinning and you think Windows is working but you can't see an image then :-
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :-
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
Defective CCFL backlight, it may have the following symptom:
All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
SOURCE: Monitor not working on Dell Inspiron laptop. Inspiron 1501 laptop
just follow the given link ur problem will bw solved
http://www.experts-exchange.com/Hardware/Q_21896519.html
SOURCE: Dell Inspiron Mini 10 Not Shutting Down Properly
There could be a corrupted file. I would try to give dell tech support a call
