Question about Wine & Spirits
I have seen AOC written on several wine labels. What does this mean?
Posted by Travis Zhermek on
Henry Topps
    New Friend:
    Problem Solver:
  • 12 Answers
AOC can be found on bottles of French wines, it stands for Appellation d'Origine Controlee. It refers to specified regions, with controls on several aspects including: variety of grape, density and size of vines, maximum yield, minimum alcohol level and processing techniques.
Posted on Feb 03, 2013
Aoc tft22w90ps
Your model is actually called the Aoc 2216Vw and the driver can be found here:
http://aoc-international-europe-gmbh.drivers.informer.com/3. Look for the driver file labeled 2216 at the top of the page.
If that doesn't work, try this link and be sure to set your filters to Windows &: http://xpdrivers.com/monitor-display/aoc/_3_3767.cfm
Hope this helps!
Apr 14, 2014 | Computers & Internet
How are wines named?
Wines are named for one of two reasons: the grape variety or the region where the grapes were grown.
The first type is named after either the sole (or principle, if blended) grape variety that makes up the wine. Many times a wine is blended; you may not find that information on the label. Each country has its own specifications that dictate the minimum percentage of the named grape that a wine must contain.
The second way to classify wines, by their region, is quite common in Europe. Instead of the label dictating whether the wine is a Merlot, Syrah, or Cabernet Sauvignon; in this case, the label will say Burgundy, Bordeaux, or Sancerre. This technique is used because many of these regions are famous for a certain grape variety.
Feb 03, 2013 | Wine & Spirits
What are the characteristics of a Reisling?
Reislings are generally characterized as sweet wines; and while many are, there are some that are not. If they display the term "trocken" on the label, this usually means that they are a dry variety of Reisling. They are often light-bodied, refreshing white wines with a high level of acidity. They usually host a variety of fruity and flowery aromas and flavors.
Why do some wines have a 'bin' number written on the label? does this refer to the quality of the wine?
Bin numbers are used as a way to help manufacturers brand their wine. It has absolutely nothing to do with quality. This branding technique is most commonly found in Australian wines
What is the best temperature to store red wines?
Red wines should be stored in the temperature range of 58-68 Fahrenheit all depends on the type of red wine you wish to store (it should be written down on the label).
Aug 14, 2012 | Furniture
What is the best temperature to store white wines?
White wine should be stored in the temperature range of 46-56 Fahrenheit depends on the kind of white wine you store (the recommended temperature should be written on the label).
Why should I store bottles in my wine rack with the label facing up?
Because when you store your bottles with the label side up, it will be much easier for you to spot any sediments that may have formed in the wine over time when you pick it up.
Aug 13, 2012 | Furniture
I have a magic chef wine cooler (Model MCWC50DBT) and the labels keep falling off of the bottles. The temperature is set to red and we don't seem to have any other problems.
All the wine chiller set 2 temp red and white, red wine temp only for 18- 20 oC , your using white wine don't set red wine temp , set only for white temp mode,white and red wine set temp are different temp
May 27, 2008 | Magic Chef MCWC30MCG Compact Wine Cooler
AOC LM700 17" LCD Screen switches to black and then comes back to normal. Power light never goes green but monitor works. LED is orange when off and in sleep mode, wakes correctly on getting input. Just...
According to LCDParts, an inverter for an AOC LM700 would cost $69.99. Specs (with picture) are available here.
Perhaps you can do a Google for lesser priced versions.
Good luck and kind regards.
Feb 08, 2008 | AOC LM 720 17" Flat Panel LCD Monitor
Wine & Spirits Logo
602 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
