Question about Wine & Spirits
Does the type of glass you use for draught beer matter in regards to the style of beer?
Posted by bill letterman on
Billy Sibley
Hi, I have been working as a beer dispense technician for over 20 years and can confirm glassware IS important for the beer.
This is due to the etching at the bottom of the glassware (nucleator) which releases the gas in the product, therefor giving rise to a lovely frothy head, poor or incorrect glassware can give rise to flat beer.
Renovate all glassware before use and approx every 3 months there on.
This process “unclogs” the nucleator.
Also do not wash glassware with coffee cups etc as this can produce an invisible film on the glass which prohibits the beer from sticking to the glass.
Hope this helps ??
Posted on Jan 20, 2020
Pieter Vleeshouwers
  • 2,027 Answers
The most important is whether the glass is appropriate for the type of user, in combination with the type of beer.
People who drink beer or people sipping (Preference is strictly personal) time that beer is and whether you lager drink or beer makes the difference thick glass at slow drinkers or thin glass for fast drinkers, beer is generally less drunk and drank something higher temperature than lager.
Pils has a priority to be drunk quickly and has a priority on the foam not by beer foam has no priority (as like in England) the foam is not rated because there remains less beer. 10 11 degrees lager 6-9 degrees for pils.
Posted on Jun 05, 2016
Openers Plus
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 6 Answers
Absolutely, glad you're asking about draft. Much better than pasteurized cans and bottles. With that even pasteurized is better in the correct glass.
Posted on Nov 05, 2014
jerry crawford
    New Friend:
    Problem Solver:
  • 14 Answers
According to beer manufacturers, yes. This is especially true for wheat beers. Most wheat beer glasses are specifically designed to tall to help trap yeast sediment at the bottom of the glass so that it does not blend with the rest of the beer while you are drinking it.
Posted on Feb 03, 2013
Which is advanced or better : Neon or LED illumination?
LED lighting is more advanced. Neon has a long history, having been used for nearly a century.Though Neon has the brightest lighting capacity, it requires maintenance. Neon emits more energy than LED lights. LED works in any climate. This makes LED a very reliable optionfor illuminated channel letters. They require much less maintenance and are more energy efficient than neon. Neon signs are easily broken. Being made of glass, they leak. LED does not have this problem . Once you get a neon sign, there's no changing it. Custom LED signs can be updated as often as you like, with whatever messages you like. Custom LED Signs Toronto Single Double Sided New Style Signs
Jul 31, 2015 | Neon Sign Inc Old Style New Orleans...
Tip
How to properly pour a Guinness
As a former bartender I have literally spent hours contemplating (and arguing with patrons!) about the proper way to pour a Guinness. Since leaving my post behind the bar, I did a little research in that matter. And to my chagrin, I was pouring the delicious stout almost correctly!
According to Guinness's website, it should take you a full 119 seconds to pour a pint. That's almost two whole minutes!
You want to start by using a glass made by Guinness or a standard tulip shaped pint/half liter glass.
Place the glass under the tap at a 45 degree angle.
You do not need to let the tap run for a second before placing the glass beneath it (unless it is the first pour of the day in which case you need to clear out the tap for about 20 seconds.)
Since a double pour is required for the perfect pint, you want to stop when the glass is about 3/4 full. Place it on the bar so that the nitrogen gas has time to settle.
Once the beer becomes a solid, rich brown color you are ready for the second pour.
Place the glass directly under the tap. If the tap has a backwards lever, use this. The back lever will let the beer pour more slowly and you will have time to draw a clover or a heart in the foam. This is a great way to impress your customers. If you do not have a backwards lever option on your tap, simply pull the lever forward and fill the beer up. This does not need to be done at an angle.
Here is a video demonstrating the way to pour the perfect pint of Guinness:
on Oct 27, 2013 | Wine & Spirits
What dies a tulip glass look like?
" It is the ultimate beer-tasting utility glass. The bulbous bottom makes for great drinking, the flared mouth allows for wonderful head formation and aroma release, and while it is short enough to handle the biggest beer styles, it is tall enough to service IPAs and other complex session beers. The Duvel glass is a well-known variant of the tulip style, and the Ratebeer tasting glass is an almost perfect example."
-http://www.ratebeer.com/ShowGlassware.asp?GWID=9
May 07, 2013 | Home
What are different types of beer glasses?
The main types of beer glasses are german/austrian steins, old english/irish tankards, and belgian/dutch novelty glasses.
May 07, 2013 | Home
Is there a certain technique involved in pouring draught beer?
Not only is there technique involved, but some brands of beer may require various techniques. Here is a video tutorial that will demonstrate how to properly pour a basic pint of beer.
http://www.youtube.com/watch?v=pCZkg_R4ZL4
Feb 03, 2013 | Wine & Spirits
Why is it necessary to have some foam on top of draught beers?
The right amount of foam (head) can be very important to both manufacturers and consumers. Too much foam will take away from the mass of the drink. This is why most manufacturers place a line on their glasses to mark where the foam should begin to best suit their beer. The foam is said to release aromas. Others simply like the aesthetics.
What is the difference between Pale Ales, IPAs, and double IPAs?
All of these beer styles are quite hoppy and bitter. They are not too different from one another, as they are within the same beer family; however they do have a few distinctive variances.
Pale ales - brewed with lightly roasted 'pale' malts and have a nice balance between hops and malt
IPA's - much hoppier than pale ales - can be found in both English and American styles, with the Americans making a more hoppy version
Double IPA's - an American style take on pale ales that loads the beer full of hops, sometimes doubling or even tripling the normal amounts found in traditional pale ales
What is a bock beer?
Bock beers are brewed in Germany and are considerably darker and stronger styles of beer. If you would like to know more about different style and types of bock beers I would recommend visiting the link below.
http://en.wikipedia.org/wiki/Bock
Cooler wont cool below 48 degrees.
Keep a thermometer handy. (adjust temperature control knob accordingly)
Periodically monitor temperatures inside your cooler. (adjust as necessary)
Keep the refrigerator door closed as much as possible to avoid temperature fluctuations
The temperature of the refrigerator compartment is
controlled by adjusting/setting the thermostat control
knob, located on the ceiling of the refrigerator
cabinet.
To start the refrigerator, and achieve maximum
cooling quickly;
• Turn the temperature control knob (using a coin
or screwdriver) clockwise to the furthest
(maximum) setting on the darker blue section of
the graduated control dial.
• Allow the refrigerator to run at this setting for 3~4
hours.
• When maximum cooling is achieved, turn back
the temperature control knob setting to the 2:00
o'clock position on the graduated blue control
dial.
• Correct cooling temperature is a key factor to
consider in storing and dispensing draught beer.
• Optimum temperature for serving draught beer is
between 34ºF ~ 38ºF.(1ºC ~ 3ºC)
• To maintain temperatures ranging between
34ºF ~ 38ºF.(1ºC ~ 3ºC) We recommend the
thermostat knob be positioned at the "2:00
o'clock" setting on the graduated blue control dial.
• To turn off the refrigerator, (no cooling) rotate the
control knob to the "0" position.
Jan 31, 2008 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Wine & Spirits Logo
1,075 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
