Question about Wine & Spirits
What is the shelf-life of beer? - Wine & Spirits
Posted by igor doppler on
rodney ashkel
    New Friend:
    Problem Solver:
  • 13 Answers
Beer does not spoil in the same ways as other drinks. When a beer spoils, the taste characteristics change, not so much the texture. Most beers retain their quality for about 6 months. If stored properly, it should still taste good for an additional 4-6 months.
Posted on Feb 03, 2013
How long can you keeo sherry cooking wine?
Though sherry tends not to spoil in the traditional sense, this fortified wine actually does have a shelf life. Most types of sherry can be kept unopened for up to three years, however Pale Cream sherries have a shelf life of two years, and Fino and Manzanillo sherries have a shelf life of no more than 18 months.
Dec 09, 2017 | Furniture
Why is it much colder at the bottom of refrigerter
Basic law of thermodynamics... heat rises.
Sep 04, 2017 | Refrigerators
Where is the proxy port number located
In real life, a "proxy" is a person empowered to make decisions on your behalf.
In the world of computers, a "proxy-server" is a computer that holds data, and it's located "between" your computer and the computer that holds the authoritative answer. The advantage is that a proxy-server may be able to send some data to you faster than the authoritative server. Compare to going to your beer-fridge for one bottle of beer, rather than going to the beer-store to get one (or more) bottles.
Typically, web-browsers that are configured to interface with proxy-servers try to connect to port '8080' on the proxy-server.
Mar 07, 2015 | Computers & Internet
What is the shelf life for cmos battery
If you mean how long will it normally last in use, the answer is typically several years 2-3. On the shelf, not being used, it is probably about 4-6 years. Actual results will vary depending on when the battery was actually made (and therefore how long it was sitting on the shelf before it reached you) as well as how it has been stored. Cool dry conditions lead to long shelf life, whereas hot humid, tend to reduce shelf life.
Sep 07, 2014 | Computers & Internet
What is an oyster's shelf life?
most shellfish have a short shelf life but oysters have a long one of up to 4 weeks.
Apr 17, 2013 | Cooking
What is the shelf life of soy milk compared to whole milk?
soy milk usually comes in aseptic packaging. In this case, it doesn't have to be refrigerated and usually has a shelf life of few months. Once it is opened, it can be refrigerated for about 10 days. Whole milk must be refrigerated and usually has a shelf life of about 1-2 weeks.
Feb 04, 2013 | Cooking
What is the shelf life of Dr. Pepper?
According to the official website of Dr. Pepper, the shelf life of diet products containing aspartame or aspartame/AceK blends is 3 months. All plastic bottles have a shelf life of 3 months. Sugar products (sugar or high fructose) that are in a glass/can have a shelf life of 9 months.
Feb 04, 2013 | Wine & Spirits
What are trappist beers?
In order to be considered a trappist beer they must fulfill two requirements - the beer must be brewed onsite at a trappist abbey and they must be brewed for non-profit purposes. There are currently 6 remaining brewing abbeys in the world - five in Belgium and one in the Netherlands. The most recognized trappist beer is Chimay.
Feb 03, 2013 | Wine & Spirits
Used as beer fridge but contents freezing
The defrost timer in the unit is probably bad take a look at it there should be a timer with a slot in it around the thermostat that you can turn with a common screwdriver the timer should click and go into defrost mode and the unit should shut off, if the unit shuts off and it still doesn't defrost you either have a thermal cut-out that is bad in the freezer next to the heater element or the heater element itself is bad. Let us know :-)
Sep 14, 2007 | Jenn-Air JUC2450ARS Compact Refrigerator
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Wine & Spirits Logo
205 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
