Question about Wine & Spirits
How should beer be stored? - Wine & Spirits
Posted by yael toppy on
igor doppler
    New Friend:
    Problem Solver:
  • 15 Answers
The most important aspect about storing beer is keeping it away from light; therefore you should store beer in a dark place, like a cellar. The second factor to consider when storing beer is temperature. Most beers should be stored at a cool temperature, not frozen.
Posted on Feb 03, 2013
Can't remove key from ignition on a 2001 aztec Pontiac
Rack the shift lever from Park back to Drive and back to Park. The same happened to me, frightened me to death, I was outside a beer store in a bad area and wanted beer but didn't want to leave the key in and I could lock the car, because the key was stuck!
Dec 12, 2015 | Pontiac Cars & Trucks
Where is the proxy port number located
In real life, a "proxy" is a person empowered to make decisions on your behalf.
In the world of computers, a "proxy-server" is a computer that holds data, and it's located "between" your computer and the computer that holds the authoritative answer. The advantage is that a proxy-server may be able to send some data to you faster than the authoritative server. Compare to going to your beer-fridge for one bottle of beer, rather than going to the beer-store to get one (or more) bottles.
Typically, web-browsers that are configured to interface with proxy-servers try to connect to port '8080' on the proxy-server.
Mar 07, 2015 | Computers & Internet
How to make beer at home
visit the store at ambersuds.com for home brewing recipies, guides and equipment
Dec 27, 2014 | Wine & Spirits
Is The Budweiser Story fact or fiction?
the story is amongst many urban legends concerning vendors and their reactions to certain clients at that time. Currently, Budweiser is not owned in the USA, and would have been the actions of the delivery driver and not the brewery.
Nov 05, 2014 | Wine & Spirits
Budweiser story of delivery to an Arab owned store after 9/11. The arabs we celebrating the 9/11 disaster in New York to the twin towers.
heard the same story concerning a driver for Pepsi, and again concerning Coke, Doritos, Lays.... whether or not factual, these stories tell us how we wish we could respond directly to such an atrocity as 9/11
Sep 16, 2014 | Wine & Spirits
What is the shelf-life of beer?
Beer does not spoil in the same ways as other drinks. When a beer spoils, the taste characteristics change, not so much the texture. Most beers retain their quality for about 6 months. If stored properly, it should still taste good for an additional 4-6 months.
Feb 03, 2013 | Wine & Spirits
Do canned beers taste different from bottled beers?
Essentially, no. Some people may argue this statement, but basically what they taste is the aluminum. Try pouring the beer into a glass - it will taste the same. Cans are a great way to store beer; however they are not often used due to the cost surrounding their manufacturing process.
New danby kegerator - tastes like rubber hose
There is a check valve inside the coupler of the danby kegs that cause this problem. The valve is mainly there to prevent beer from back-flowing when changing the keg. Next time you change your keg check for a little black plastic retainer and also a small white plastic ball inside the coupler. Remove those (or just smell it) and you should notice that this is the taste/smell your beer has. I removed mine after this discovery, and there isn't any issues with the taste/smell since. I've heard this is a common issue with the Danby D coupler systems. Also, you won't have any issues with beer backflow when you change the keg, provided the line going to the tap is empty (which usually is if keg is kicked).
Dec 30, 2007 | Danby DKC646BLS Full Size / Pony Beer Keg...
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Wine & Spirits Logo
238 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
