Question about Crafts & Hobbies
What is spray painting? - Crafts & Hobbies
    Filmmaker:
    Uploaded 5 video answers.
    New Friend:
  • 137 Answers
Spray painting is a painting technique where a device sprays a coating through the air onto a surface. The most common types employ compressed gas to atomize and direct the paint particles.
Posted on Feb 03, 2013
6ya staff
SOURCE:
Can I use spray paint in my back yard?
Sure, why not?. I've sprayed kitchen cabinets in my driveway, dining room chairs (metal, with auto paint) on my patio, wood paneling and more.
I would suggest using drop cloths or plastic to cover whatever you're not spraying, as spray will spread, especially if you use a water-based paint.
Dec 31, 2015 | Air Tools & Compressors
Paint gun splatters paint on car
The needle valve in the spray head needs to be cleaned or replaced.
Nov 21, 2013 | Binks Paint Spray Gun Repair/rebuild Kit...
Convenioal gun sprays thinner but not paint
Most guns have a paint strainer inside (filter) if this is not cleaned regulary it will let through thinners but not paint
Feb 05, 2013 | Binks Conventional Spray Gun with 1Qt...
In trying to spray oil base paint, I get very low fluid flow (if any) from the cup to the gun. I've cleaned the gun and insured the hoses weren't clogged. Changing the adjustment valves...
How does it spray if you dump the paint out and put paint thinner in the cup? If it sprays paint thinnner, but not the paint, your paint is too thick. Thin it down by 25% and try a little. Keep adding thinner until the paint sprays out of the gun in an acceptable manner. Your gun probably has a 1.1,or 1.4 fluid tip. this is for spraying lacquers or automotive paints that are very thin. to spray oil based paint, your would need a 2.0 or 2.5 or bigger. not really what this gun was made to spray.
Jul 20, 2011 | Binks Hvlp Spray Gravity Gun With 1 Liter...
How could i put a glitters with my wall at my facebook
  • SPRAY CLEAR GLITTER ON DRY WALLS -- Go to your local craft store and pick up a couple cans of spray glitter. You want a clear base so you can keep your current wall color. Look for a spray that says something like clear glitter finish or clear glitter sealer. Then just spray your walls with the clear glitter spray.
  • PAINT YOUR WALLS WITH GLITTER SPRAY PAINT -- If you want to change the color of your walls you can spray paint them with colored glitter spray paint so you get the painting and glitter done in one easy step. However, spray paint can be expensive and you may find it is difficult to get a nice even coat of paint. So this method would be good for a small room or an accent wall.
  • PAINT YOUR WALLS THEN ADD GLITTER -- This is the cheapest way to get the glittery look you want. Buy your wall paint in the color of your choice. Then buy tubes of glitter in the craft section. As you paint your walls, do one small section at a time. Then pour out a bit of glitter on a paper plate and gently blow on the glitter so it blows onto the freshly painted wall. The glitter will stick to the wet paint. Then move on to the next section and do the same thing! If you are applying two coats of paint to your walls add the glitter to the second coat.
  • Feb 27, 2011 | Graphics RSA SID700-6-60-48-5...
    Porter cable PSH 1 - clogs even with thinned paint compressor 4 gal 5.1 scfm
    strain paint befor using. run water in gun or thinner to see if it will spray it before using and mix paint to the consistancy that spray gun or paint requires for spraying ( fine strainer)
    Feb 04, 2011 | Porter Cable Gravity Feed Paint Sprayer
    Porter cable spray painter PSH1 it says what you can spray with it and I want to spray water base paint can I do it with this painter it is new and I didn't relize it was onl for laciur paint thank you...
    Be sure to filter the paint you are trying to use so that you aren't dealing with large lumps of paint. You will need to experiment with hose pressure to get proper spray quality, and set the mixture control for a fairly fine mist as the paint is likely to be more fluid. Fan control is set so that you don't get an unpainted space in the middle of the paint swath. Make sure to wash the gun thoroughly after painting. If you are doing a lot of painting, expect some nozzle wear over time as the water base paint is somewhat gritty. Don't forget to trigger 'off' before the end of each stroke and trigger 'on' after starting the return stroke to keep running at a minimum. Good luck!
    Jun 19, 2010 | Porter Cable Cable PSH1 HVLP Gravity Feed...
    Painting vehicle wheels?
    You can paint it with reguslar paint as lomg as you clean it real good and ruff it up with sandpaper. You will have to spray primer on it first before painting it. I hope this helps. Don't forget to rate this answer.
    Feb 07, 2009 | RTO How To Paint Your Own...
    Spraying troubles
    Off hand I would say that you have the wrong spray tip for the paint that you are spraying or that the tip is worn. Another thing that it could be is the little piece of rubber behind the tip is worn or missing. My first suggestion is check the tip size with the recomendations of the paint that you are spraying (You will find this on any specification sheet from the paint manufacturer.. If the size is correct replace the tip. A new gasket comes with a new tip. Hope this helps.
    Dec 30, 2008 | Graco DuoGlider 7951 - G Collection Twin...
    Crafts & Hobbies Logo
    112 people viewed this question
    Top Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    thinksewfast
    ray gallant
    Are you a Craft and Hobby Expert? Answer questions, earn points and help others
