Question about Wine & Spirits
What is a lambic beer? - Wine & Spirits
Posted by roger nori on
dave
    New Friend:
    Problem Solver:
  • 13 Answers
A lambic is a very unique style of beer produced in a very small region of Belgium. Some of the more popular characteristics of this beer include:
- Dry and sour aftertaste
- They are wheat beers that used unmalted wheat
- Uses a process called spontaneous fermentation where the yeast is not added directly to the wort, instead the vats are left open and wild yeast from the area are allowed to naturally fall into the vats
Posted on Feb 03, 2013
What kind of beer is best paired to drink with a chocolate dessert?
Pairing beer and chocolate can be a very fun and tasty treat. Depending on the type of chocolate, there are several beers that could compliment the taste. Below is a site I found that goes through various chocolates and their best beer pairings.
http://billybrew.com/beer-and-chocolate-pairings
Feb 03, 2013 | Wine & Spirits
What temperature should beer be at for drinking?
Each style of beer has a certain guideline for suggested drinking temperatures. Here are a few:
- Wheat beer and pale lager= 45-50F
- Pale ales and amber/dark lagers= 50-55F
- Dark ales, porters, stouts= 55-60F
- Fruit beers= 40-50F
Someone once told me that I should wash my hair with beer. What will a beer wash do for my hair?
Washing your hair with a beer wash once in a while can add some shine to your locks. The following site will provide you with a recipe for creating a great beer shampoo.
http://www.ehow.com/how_4465094_make-beer-hair-wash.html
Does the type of glass you use for draught beer matter in regards to the style of beer?
According to beer manufacturers, yes. This is especially true for wheat beers. Most wheat beer glasses are specifically designed to tall to help trap yeast sediment at the bottom of the glass so that it does not blend with the rest of the beer while you are drinking it.
What are ice beers?
Ice beers are called such due to the process in which they are brewed. The beer is chilled prior to filtration, forming ice crystals; which may or may not be removed later. Generally, ice beers have a slightly higher alcohol level content.
How should beer be stored?
The most important aspect about storing beer is keeping it away from light; therefore you should store beer in a dark place, like a cellar. The second factor to consider when storing beer is temperature. Most beers should be stored at a cool temperature, not frozen.
What is craft beer?
In its most simple form, craft beer is any beer not brewed by one of the big brewery corporations. The term craft beer is most commonly used to describe a beer made by an independent brewer in small quantities.
What is a porter beer?
Porter beers originated in London. They are typically dark-colored beers brewed with brown malt and plenty of hops. Many people refer to porter beers as stouts; however this is not the case. Porters are sweeter and have lower alcohol content.
There was a scientist who after doing research, found that color of skin of animals vary with change in distance.One day he started to chase a beer. He walked 1 mile towards north, then turned and walked 1...
There was a scientist who after doing research, found that color of skin of animals vary with change in distance. One day he started to chase a beer. He walked 1 mile towards north, then turned and walked 1 mile towards east and then caught the beer and radio-rib boned the beer Then he left the beer at that spot and returned to his base-station taking a turn towards south (walked 1 mile towards south). Then what was the color of beer at that spot?
Aug 18, 2010 | Computers & Internet
Danby Beer Keg dispenser fridge.
Draught (or Draft) beer is almost always un-pasteurized and therefore is more fragile. It should be consumed after being "tapped", and is generally truer to the flavors of the ingredients as pasteurization exposes the beer to heat and changes the flavor profile. Always use brewery approved beer line if you want to have foam free fresh tasting beer. Serving it through a plastic tube from the hardware or discount store or the plain vinyl tubing in your beer tap system you will wind up with a foamy, off tasting beer. Real draught beer is not pasteurized. It must be kept refrigerated between 35F. and 44F. A beer will become wild, turn sour and cloudy in a day or two. Below 44F. a keg of draught beer should last 20-30 days before it loses it's fresh brewery taste and aroma. Craft beers (micro brews) tend to have a shorter shelf life and you should contact the brewery for their recommendations. Why does my beer foam up? The 3 most often causes of beer foaming up are: The temperature of the beer keg The balance of the draught beer system pressures The cleanliness of the draught beer system I would suggest that you clean or replace the beer transport tube...
Aug 11, 2007 | Danby DKC645BLS Compact Beverage Cooler
Wine & Spirits Logo
191 people viewed this question
Top Wine & Spirits Experts
Andrew Taylor
Andrew Taylor
Don A
Don A
Chris Walker
Chris Walker
Are you a Wine and Spirit Expert? Answer questions, earn points and help others
