I ALREADY PAID FOR MY RADIO FROM THE DEELER BUT IT IS FOR MY OLD ACURA INETGRA 1990 BUT EVERYBODY IS GREEDY AND WANTS MONEY TO TURN IT ON AND HALF ARE ALREADY WRONG SO I AM PAYING FOR FALSE INFO
id have already took it apart and found what smoked.
and why. ID the the actual wire , conn, or switch that smoked
then see if someone put the wrong fuse in that circuit. (bigger is bad)
its and old car, expect stuff like this, and more to follow.....
entropy , always wins...
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. Call an Acura dealership with that serial number and they should be able to provide you the code. Or you can take it directly to the dealer but you will be charged labor.
Could be fuel filter. This will restrict a lot. If it is automatic it might be your transmission control module. Your check engine light should be coming on if it's not already.
Turn your radio off
Press the #1 Preset button and #6 Preset button at the same time and while doing this with your other hand turn your radio on and your will get a stereo code. Call the dealer and see if they will give you the unlock code for the stereo code otherwise go to stereo-code.com and pay $ 28.00 to get it quick
I did a little bit of browsing, and i found these solutions. I would highly reccomend the first one, with the phone call.
"I just tried calling acura USA (800) 382-2238
and they will give you all the assistance you need. Forget paying money for a code to the dealers...
===> This one sounds like a very good solution, don't try to fix it yourself."
==Fix it Yourself Solutions== "You don't need to remove the radio. There's a non-use "button" between
the fog light and rear-window defroster buttons. You can pop that off
with a small screwdriver. Then you can read the S/N off the bottom of
the radio with a flashlight. Acura of Memphis gave me the code over the
phone."
"=>look at the back of your Ashtray and there will be a sticker on it with your 5 digit code........done!!!
=>I checked the ashtray and the fuse cover - nothing. I assume that's where the original owners decided to hide the codes.
=>you have to pull out the ashtray thing and it should be on the back. But if you already did that then it's all good.
I wouldn't reccomend doing this unless you know what you are doing, you could destroy your ashtray."
and they will give you all the assistance you need. Screw paying money for a code to the dealers...
