Question about GE Cooktops
How do you change the heating element for a GE profile model JSP47BOF4BB
How to replace a radiant burner element wb30t10062 on a cook top not a combo, oven and cooktop
Search for my solution for a replacing the element on a JP939/JP969. That should help for similar GE models.
Sep 10, 2011 | GE 30 in. Profile JP939 Electric Cooktop
GE profile JP939 flashing F152, how do I fix?
F152 means the right front burner has failed, the sensor in it is bad, the burner will need to be replaced. If you go to the following web page, and pick out your exact model number, you will see diagrams and parts lists that will help you get this fixed. You can order the element from that website, if you choose: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JP969 Good luck, and hope this helps.
Nov 28, 2010 | GE 36 in. Profile JP969 Electric Cooktop
Cooktop burner cuts off and on. does not maintain heat properly
bad thermal sensor in the element, do they all do it or just one?
if it is just one then replace the element if it is all the replace main board, this can be pricy in some models check the users manual for waranty info some brands/models cover such items for several years
Sep 19, 2009 | GE 36 in. Profile JP960 Electric Cooktop
Radiant cooktop blew a fuse?
Call the service tech it;s under warranty and, this model is notorious for this fault
Apr 21, 2009 | General Electric 36 in. Profile PP962...
Ge profile electric counter top stove
I did not receive instructions with my G E Profile cook top Model No. 80030750434). There is a build up on the elements which I am having problems removing. Should the top be scraped while the stove is hot or cold? What is the best cleaning product to use?
May 01, 2008 | GE Profile JP930 Electric Cooktop
Problem with large surface unit
The element is bad. On some models the elements have a 5 yr warranty. Check your owners manual.
Sep 26, 2007 | GE 36 in. Profile JP960SCSS Electric...
Cooktops Logo
75 people viewed this question
Top GE Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a GE Cooktop Expert? Answer questions, earn points and help others
