HP Compaq W17q Monitor Logo
Posted on Feb 03, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I connect a DVI to a Compaq W17q - HP Compaq W17q Monitor
Anonymous
Level 3:
Guru:
  • HP Master 2,178 Answers
  • Posted on Feb 06, 2013
Anonymous
HP Master
Level 3:
Guru:
Answers
2178
Questions
0
Helped
390410
Points
6614
No - it uses VGA 15-pin D-type connector according to the specs.
My W17q monitor suddenly stops working
go into control panel , display setings and adjust display to never turn off
1helpful
How do i connect my Samsung plasma tv to my Compaq Presario SR1601NX?
Hi Prissy,
You get USB to HDMI/DVI cables with which you can make the connection with your TV to PC
Hope this helps you.
Regards
Nat
The guide you told me to use did not have my model number W17q so I could not use any of the information.
Hello, try this link to the hp website where you will be able to view a user guide.
http://h10032.www1.hp.com/ctg/Manual/c00881436.pdf
If you want further info, then go to the main hp website:
www.hp.com
and select 'Support and Drivers' then on the next page, type in your
product 'W17Q' press 'search' then on the next screen scroll down and you'll see several options from which you can choose.
Regards,
nicam49
My compaq w17q won't turn on. Help?
check if your compaq w17q power cable is properly connected to the AC adopter if not the change the power cable.
How do i connect my compaq pc to tv
Without the model number comptuer, I cannot verify what outputs your comptuer has. Without this, I will provide the various ways a PC can be connected to a TV.
1. Use a VGA to DVI adapter (HD-15 pin to DVI). Use either a standard VGA montor extension cable (cheaper) or a DVI extension cable (more expensive) to make the connection
2. If you computer has a DVI output, use a DVI extension cable only
3. If your computer has HDMI output - use a HDMI to DVI adapter and either a HDMI or DVI extension cable.
In all 3 cases, you will probably need to go to the comptuer's Display Properties and adjust the screen size so it looks OK on your TV (go to the Control Panel - find Display) and adjust the screen resolution to match the format of your TV.
One note - when purchasing DVI cables, understand that there are 3 types - DVI-D (digital), DVI-A (analog) and DVI-I (digital and analog) and that the pin outs are different. Be sure to check your the owners manual of your TV to find which connection it needs.
Here is a good reference for DVI types
http://www.interfacebus.com/Design_Connector_Digital_Visual_Interface_DVI_Bus.html
9helpful
I have a compaq w17q monitor and the osd locked message keeps popping up. how do I get this to stop?
Hold the menu button in WHILE turning on the power. This toggles the state of teh OSD lock.
No sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
1helpful
Compaq w17q monitor keeps going on and off how can i fix it?
1. check the power cords- make sure all are snug.
2. check and make sure no pins are bent in the cord to the computer
3. make sure that the monitor is not in auto-power save. Or in auto off mode. For example- is the light amber or green.
4. finally, make sure that your settings on your computer are not set to power off your monitor- as in a blank screen saver, power save or hibernate
1helpful
Using a Compaq WF1907 monitor with a Playstation3
No. HDMI transfers picture and sound, but DVI does not. You need a audio line as well.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
