You can not power the camera while plugged into a usb port on a computer, only using a wall plug or car lighter. Also when you insert a battery into a hero3 or 3+ black model you must wait 4 seconds before trying to turn it on or it wont turn on until you remove the battery and then reinsert it while waiting 4 seconds to try and power it up:
Need a night vision or flat lens for your gopro contour or drift hd cameras?
RageCams Will Price Match & offer better custom tailored installation kits with their lenses to fill the gaps & hold focus which is very important. We offer more HQ lenses / replacement parts & have serviced more gopro cameras than anyone on the net & at the highest quality service available. Scratched your gopro lens or damage your led readout screen? We can replace it for you quickly or offer you the parts to do it yourself. HD Wearable Video Custom Mods By RageCams
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
