Question about Proton MM2701VT 27" TV
My tv shuts off - Proton MM2701VT 27" TV
Posted by jmartel2466 on
Marcos Lopes
    Sergeant:
  • 259 Answers
Does the tv have remote control? If is make sure did got wet somehow.
open remote control and check if is dry.
Posted on Feb 03, 2013
We have a VizioE420I led smart tv that will just shut off & then turnitself back on at different intervals? we were told by the tv specialist it was the dish satellite box....the dish guy said it was...
Make sure your remote is not shutting off the TV. Turn the TV on and remove the batteries from the remote or take it into another room for a while. If it still shuts off, the power supply unit int the TV is overheating and has a thermal safety that shuts the TV down to avoid a fire. If there is a large amount of dust build up in the back of the TV. Get a can of compressed air and take the TV outside and blow the dust out. This may help.
May 31, 2014 | Vizio L37 Television
Tv shuts off after 10 seconds
one of the energy cables is damaged, so tv 'safety protcol' turns on, not to burn shuts off.
go to service
Apr 18, 2013 | Sylvania 6427TE 27" TV
Tv will not turn on i push power on button and blue lights click on an tv acts like it will come on but then tv shuts off and no picture appears
The blue light merely indicates power is getting to the TV. When you press the power on button, the defective power supply shuts the TV down immediately
Jan 06, 2013 | JVC LT42P789 42 in. LCD TV
Tv shuts off on start up and light flashes six times
more loose inside your tv that is a reason for your tv shut off you need to resolder the printed board
Jun 24, 2010 | Sony FD Trinitron WEGA KV-32HS420 32" TV
I have a Craig Model CLC501 and have to use both Comcast's control and the TV control in order to shut off TV. I have programmed everything else but can't seem to get tv to shut off with Craig control. Do...
Most cable supplies provide a switched receptacle on the rear of their cable boxes. Plug the power supply for the tv in there if you want the cable box to shut the tv off when you shut the cable box off.
Sep 24, 2009 | Craig Televison & Video
Tv shuts itself off
Look for the computer processor inside the TV. It needs to be cleaned. A can of compressed air will work. The processor is overheating and causing the tv to shut off. Look for the small fan that is supposed to keep the processor cool then remove the dust.
Oct 22, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Lcd tv
What is the model number and mostlikely the set needs the software updated.
Aug 20, 2008 | Samsung Televison & Video
TV shut off will not stay on.
Sounds as though you have a video problem. It may be the convergence chips. The TV is shutting down do to a default in the circuit ( the set knows there is an error of somekind so it shuts down to protect itself). This is a problem that needs a pro trouble shooter since it could be in about any board. Sorry I couldn't help more
Ed
NC Electronic
Mills, Wyoming
Jan 07, 2008 | Mitsubishi VS-55707 TV
Proton MM2701VT 27" TV Logo
29 people viewed this question
Top Proton Televison & Video Experts
matt martin
matt martin
ray gallant
Are you a Proton Televison and Video Expert? Answer questions, earn points and help others
