The glass under the touchscreen on my Epson Workforce 845 is cracked and the touch screen does not respond. How might one repair the glass so the touchscreen will work again?
The touchscreen is sold as one part, you can't buy or replace just the glass. There is a capacitive layer glued to the glass that is probably damaged.
Thanks very much, Justin. I"ll check with Epson to see how to get one.
Justin/Steve, did either of you ever manage to solve the broken touch screen problem on the Workforce 845? I too have a broken screen and am trying to solve the problem. Any advice would be greatly appreciated. Thanks!
Well I looked on a few sites that sell parts for this model. The touch screen is not sold. Thiss implies it's not cost effective to replace the part. You would be better off replacing the printer.
I called a couple of computer repair joints and found one in Manchester, NH that had a junked 845. He sold me the screen unit and the repair schematics from Epson for 20 bucks. If I could find a local with one I'd be surprised if others couldn't do the same.
SOURCE: Need to Fax from my Computer using an Epson Workforce 600
GET YOUR SOLUTION FROM EPSON
HERE IS YOUR SOLUTION
http://www.epson.com/printer/prob676ijt65/solution
a17
SOURCE: I get error 0408 when i try to fax. Using epson
Communication error,try defaulting the machine ,check the line with a good telephone make sure you have dial tone.
Good luck
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
SOURCE: printer offline on wireless home network
first make sure the wirelss is enable and you are able to ping the print server .Go to printer and faxes option and choose the printer model which you installed just right click on it you will see the option of use printer online.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
