Look inside the drum at the place where the fin was on the drum.
Do you see any screw holes now showing?
That will tell you that you need to take the machine all apart and re-fasten the fin on with some screws, unless the holes are stripped out in the fin itself, in which you will need to get a little bigger screws, or buy a new fin.
Oh yes, I have been using an epoxy cement in a tube that has 2 chambers, and this may help you.
I think it would work here, but will not be strong enough to glue the fin back on.
I sort of think it would stand the heat if you used it to help secure the screws into the fin.
Honestly, to me the new fin sounds " hard to get".
Be blessed.
SOURCE: Dryer fin on model MDE7400AYW fell off.
Take the door off. Do this by first loosening the screws on the hinge.
Then loosen the screws on the left (they hold on a plastic flange-type thing) that hold the front panel on. Once it's loosened, then the door hinge will have room to wiggle out.
Once the door is off, then the front panel will swing down--and you can lift it off the flanges that hold the bottom of the door.
Now you have access to the drum and can reinstall the fin.
SOURCE: My inside fin fell off I need to know how to open
remove front cover1st then you can access screws to remove top cover
