Dell Vostro A860 Notebook Logo
Posted on Feb 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
When in insert a disk, it spins. But within a few seconds it starts making a repetitive mechanical error sound. It hasn't been working for about 6-9 months.
max carson
Level 3:
  • Dell Master 7,627 Answers
  • Posted on Feb 03, 2013
max carson
Dell Master
Level 3:
Answers
7627
Questions
Helped
1013665
Points
21773
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here: http://www.dell.com/support/drivers/us/en/04/Product/vostro-a860
5 Related Answers
Anonymous
  • 2961 Answers
  • Posted on Jan 26, 2007
SOURCE: DVD drive cannot recognize DVD disk, but can read other CDs
I'm assuming you have tried a different dvd also and no joy, but it may need a lens clean or it is unable to read dvd anymore as the tracks are closer together than a cd and the alignment of the laser is faulty. Notebook roms are replaceable but only mainly from your notebook manufacturer. You could also use an external dvd writer via usb, although this then doesn't make your notebook as portable, if you need to read a dvd disc.
Anonymous
  • 3940 Answers
  • Posted on Jul 06, 2008
SOURCE: CD/DVD drive stopped working gradually
  1. Ensure the Drive is seen in MY Computer
  2. Try removing the upper and lower filters per this article: http://support.microsoft.com/kb/314060
If the drive is seen in BIOS and in MY COMPUTER, but will not read any media after running the microsoft fix and rebooting, then replace the drive.
Anonymous
  • 2110 Answers
  • Posted on Jan 30, 2009
SOURCE: CD not being read from CD/DVD ROM Drive on Laptop
try to clean the cd drive lens with a lens cleaner...
Anonymous
  • 260 Answers
  • Posted on Mar 19, 2009
SOURCE: DVDs/CDs no longer play on my laptop
You can try cleaning the pickup lens with a cotton swab or cloth. Be careful not to damage anything. Also try a different DVD to verify the disks integrity.
Good luck.
Aseem
  • 68 Answers
  • Posted on Sep 29, 2009
SOURCE: dell Inspiron 8600 Cd RW/DVD has stopped working
this problem occurs when the lens of the drive gets weak or broken
you can either buy a new drive or just get the lens of the old drive replaced
yes its possible to replace a cd rw/ dvd drive with a dvd rw drive
Dvd+rw nd-2100ad no disk in drive error
Can you see DVD-RW drives indicator busy when you insert that disk for a long time? if so, your drive may not going to read that disk. If it is in case of CD disk, sometimes DVD-RW just can't read it while very old CD-ROM can read! If this happens in case of other CD/DVD witch is readable by other DVD-RW, You may just try to clean the lens of your drive.
1helpful
I recently bought Sims 3 for PC. So, when I open my IBM disk tray and put the disk in, the computer doesn't recognize it and I cannot install the game. This game was a little expenisve, so I would
Hi Elizabeth,
Depending on the model of your IBM PC, it could be that it has a CD drive and not a DVD drive. The Sims 3 game is on a DVD. If this is the case you will have to upgrade your CD player to a DVD player.
To test if your drive is working insert an original music CD into the drive and see if it plays. If it does play you most likely have a CD player and not a DVD player, which means you will have to upgrade to a DVD player/writer drive anyway.
These are relatively inexpensive and retail for approximately $20 to $50.
Feel free to reply should you need any further assistance.
Best wishes,
Graemevm
3helpful
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Cant play movies from my toshibia laptop
Hi:
There are several reasons why a movie won't play, so I will run a few suggestions by you:
Hopefully ;you have a DVD drive or a DVD RW drive ?
If you insert a DVD or CD into the drive, your computer should recognize that a disk is inserted. If not the drive might be bad
You must have some sort of Software installed to make movies play, such as WinDVD, or PowerDVD
DVD-RW drive does not read disks
the DVD-RW is faulty, take it in and get another one to replace it. the clicking noise may be coming from the rack gear inside the device and causing a malfunction.
1helpful
Toshiba sd-r2002 - won't recognize blank CD when trying to write files to a CD
right click on the drive.... go to properties... under tab recording, remove tick "enable CD recording on this drive" and press apply... after that tick "enable CD recording on this drive" and press OK.
It should work.
Khypermedia DVD RW - not being consistent
Try to re-install the drivers for the drive.
Hope this helps!
DVD/CD-RW Driver
I see this problem quite often. Microsoft has a guide that will fix the issue.
Click HERE
DVD/RW Recognition Issue
+/- media matters =)
make sure you're using compatible media... some cd/dvd drive will do this spinning and spit out the media they don't recognize. if you're inserting blank cd/dvd, check the lable on the disk if you're using the plus "+" then replace it with a minus "-" then vise versa...
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
