When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your Peugeot service centre and get them to enter this code for you.
SOURCE: i have just replaced the car battery on my y reg
Please
quote ALL the LETTERS+NUMBERS on ANY BARCODES , LABELS or STAMPED IN THE
METAL
CASING.
SOURCE: i need an unlock code for a clarion car radio i
and the
only CLARION code available for free (using a serial number ) from anywhere on
the Internet is if your radio also has a
BARCODE SERIAL NUMBER beginning with
C7000000
+ + + + on a label somewhere on the
metal casing.
If not then it will only be available from your Main Dealer or a Decoding Service or your
local Car Radio / Audio Store who will connect a laptop to read/recode the
memory chip (EEPROM)
SOURCE: MY CAR RADIO IS LOCKED AFTER DISCONNECTING THE
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0cm 5.4pt 0cm 5.4pt;
mso-para-margin:0cm;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Your
radio is made by CLARION and the only CLARION code available for free (using a
serial number ) from anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with
C7000000 + + + + on a label somewhere on
the metal casing.
memory chip (EEPROM
SOURCE: I need my radio code after replace the battery
Normal
0
false
false
false
font-size:10.0pt;
Your
the metal casing.
memory chip (EEPROM
