Just bought HMDX Jam wireless speaker, used it once, left it in briefcase for 3 days, turned "on"; Plugged into my computer with USB/Micro USB cord; Red charging light is on, but blue Bluetooth light NOT on; My Windows/PC computer now cannot find the device to pair with it. I have uninstalled the device and now cannot even install it because computer cannot find it. What to do?
Go to your Bluetooth settings, go to the "Audio/Video" tab, under the "Content Protection" section uncheck the "Connect to content protection enabled headset only" and your bluetooth speaker(s) should now work.
Posted on Apr 14, 2015
SOURCE: Unable to set pairing between jabra bt 125 and bluetooth device
You simply need to hold the button down for a long time, it will flicker blue at first, don't let go of the button, and it'll turn blue for pairing.
Posted on Feb 05, 2008
SOURCE: HOW TO INSTALL A MOTOROLA H550 BLUETOOTH HEADSET
Usually to pair a new device like that, there would be some trick to set it up. Im not familiar with your exact model, however ive had success with holding some buttons in.
Usually you would hold down the power button, or perhaps the volume up and down together, hold them down for a few secs and the light will go blue/red/blue/red to show its in pairing mode.
Posted on Jun 18, 2008
SOURCE: pairing the insignia bluetooth wireless headset with an ipod
Perhaps either its pairing log is full, thay hold a number of pairing internally, and may need to be cleared to make room for another....or the headset may need to be reset, either way...heres the scoop....to clear the pairings hold the track forward/track backward buttons down together until the light flashes Purple....Empty pairing log......
If not then try pluging in the set to the charger and holing the 2 volume buttons down the same way..this will shut it off and reset it if it went a bit screwy on ya.... Merry Christmas
Posted on Dec 25, 2008
SOURCE: jabra vbt2050 won't connect
Jabra VBT2050 - You have to hold the round button in until the light stays lit (about 20 seconds) this will put it in discoverable mode, the pin is 0000, I have [email protected] service and it works just fine. Hope this helps out!
Posted on Feb 08, 2009
SOURCE: old phone quit and blue tooth won't pair with new phone
Hold the volume buttons on the side while holding the call button for 10 seconds. It will reset the bluetooth and remove any other devices it may have been paired to. Then turn it off, back on and it will eventually stay lit blue and then you need to set it up through your phone. I hope this helps, I had the same problem and mine is working fine!
Posted on Sep 22, 2009
