The "Win32 config" system folder and the files within it are crucial to the Windows Operating System's stability. If any of these files become damaged or corrupted, you likely receive error messages. Fortunately, Microsoft puts the files to repair these problems on the installation CD that comes with your operating system. The original install disk offers a quick way to repair the system. Damaged files are replaced in only a few minutes.
Insert your Windows CD into the computer drive. Restart your computer. On startup, look for the message, "Press any key to boot from CD" and press "Enter" on your keyboard. You should see the blue "Welcome to Setup" screen. Click "Enter" on the "Welcome to Setup" screen. Read the "Microsoft Software License Terms," then press "F8." Use your arrow keys, go down and select the Windows installation you want to repair. Press "R" for "Repair." Windows will now start to restore the Win32 System to your computer.
SOURCE: missing or corrupt file
See if you can go into setup by pressing the F8 key when you first turn on the laptop. It should bring you into a menu, if it does then choose safe mode. If you can get into safe mode then do a system restore back to a date when the laptop was last working properly.
If you can't get into safe mode then your system files are corrupt and you'll need to reset the laptop back to factory default and I believe it can be done by pressing F11 when you first turn on the laptop assuming the partition with the info on it is still there.
If you can't do this then you'll need to find the cd's that came with the laptop and install the operating system first and then the drivers and applications cd.
Let me know if I can be further assistance.
Ben
i dont think you got the entire solution its to long to add through add comment just download the xp3 burn it with image burn http://www.microsoft.com/downloads/detai... http://www.imgburn.com/ as an ISO
