Question about Toshiba Satellite Pro 6100 Notebook
Toshiba sp6100 recovery restore image - Toshiba Satellite Pro 6100 Notebook
Posted by Rosslyn Kent on
1 Related Answer
Anonymous
SOURCE: laptop
Sir,
i assume you are asking for a restart when your computer is stuck and you cat do a normal restart.
In such event keep power key (that you use to start the laptop) pressed for few seconds. that will force shutdown it. then you can restart the pc like normal.
Posted on Dec 04, 2007
How do I reset my Toshiba Satellite 1800-S207 laptop to original factory settings
Satellite 1800-S207
Windows 7 and earlier Toshiba laptops come with the factory software recovery image stored in a special (hidden) area on the hard disk. From this special hidden image, you can restore your computer to its factory-fresh software condition.
How To: Perform system recovery - Windows 7
The following article will show you how to perform a system recovery. To Recover or perform a system recovery means to take the laptop back to factory settings (default settings). System restore means to go back to an earlier point in time on the computer.
There are two methods to perform a system recovery:
  • Using Partitioned Recovery Method (Free Recovery)
  • Using Recovery CDs / DVDs / Media
Details provided at the link listed below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Perform-system-recovery-Windows-7/ta-p/279643
Restore means to go back to an earlier point in time on the computer.
Refresh means PC settings will be set to default without effecting personal files or settings.
Reset means back to factory settings. (default settings) - deleting all personal files, programs and settings. Similar to Recover or Recovery
Windows 8 Toshiba laptops have many restore and recovery options available depending on your needs. To better understand these options and how they affect your computer, please view the video available in the linked article below.
http://forums.toshiba.com/t5/System-Recovery-and-Recovery/How-To-Understanding-System-Restore-Refresh-Reset-and-Recovery/ta-p/342690
Oct 01, 2013 | Toshiba Satellite 1800-S207 Notebook
Reset to factory for toshiba nb 505 to factory out vof box
Restore Toshiba to Out of the Box Condition
If your model Toshiba laptop has a Restore partition on thehard drive then follow these steps to restore your Toshiba to the Out of theBox condition.
1. Press and hold the 0 (zero) key and at the same time, tap the power buttononce to switch on
your notebook.
2. When the machine Starts beeping; release the 0 key.
3. When prompted by the warning screen; select Yes to continue with the systemrecovery.
4. Select Recovery of Factory Default Software; click Next.
5. Select Recover to out-of-box state. 6. Click Next again.
7. Click Next to Start recovery.
8. Restart the Toshiba laptop when there restoration process finishes running.Follow the prompts that appear on the screen to set up the laptop's date, timeand language settings.
Mar 02, 2012 | Toshiba Mini Computers & Internet
Where can I get/download free restore dics for my Toshiba Satellite a-135?
Theres restoration discs and then theres the original operating system discs,restoration discs only work under certain conditions far better to formatt and re-install operating system
Mar 14, 2011 | Toshiba Satellite A135-S4527 Notebook
System restore factory settings no cd
Toshiba has built in system recovery partition in your hard drive
Make sure to back up important files in your Laptop to usb or portable hard disk before doing this.
Warning: In using System Recovery you files will be deleted, your laptop will be back to its factory settings
To access the Toshiba recovery partition, power off the laptop. Hold down the 0 (zero) key and turn the laptop on. Keep holding down the zero key until the TOSHIBA logo appears, where you should start tapping the zero key repeatedly. Stop if the unit beeps or when the TOSHIBA logo disappears. The screen should flash ** HDD RECOVERY MODE ** for a split second, then load the Toshiba recovery program right from the hard drive.
Feb 01, 2011 | Toshiba Satellite A45-S120 Notebook
How to factory reset my toshiba nb200
Well, to get the operating system back to factory settings and back to its original out of the box state, simply go to 'help' menu under 'start' menu, and type in 'recovery'. Recovery will get the computer back to its original state when you opened the box and powered it up for the first time.
An image of this state is located on the hard drive of the computer.
Jan 21, 2011 | Toshiba Satellite A205-S4617 Notebook
How do i restore my laptop to factory settings
Most Toshiba laptops require the setup disk that came with the computer when it was purchased. They only work for that model and cannot be used on other computers except that one. Sometimes, there is a recovery partition in the hard drive that can be accessed to perform a factory recovery. Consult with your users manual to determine if the latter applies. Or, log in to the Toshiba website and find out how to do a recovery for this model.
Nov 11, 2010 | Toshiba Satellite P35-S611 Notebook
I need to restore my toshiba l305 s5955 laptop using the hidden partition,but dont remember how to do it.
If you're using Vista, go into Recovery mode (or Startup Repair). In the options you'll have Factory Restor. Do that and your laptop will be restored to factory state.
Sep 27, 2009 | Toshiba Satellite A100-S8111TD Notebook
HOW DO I RESTORE TO FACTORY WITHOUT DISK
You need to have the recovery disks (2 disks) so that you can do that since the OS needs to be reloaded including the original programs and drivers, from the second disk. The first one is for erasing your HDD's contents. You need to check if you have the Toshiba Recovery Disk Creator program. If you do, that means your HDD has a hidden partition and you are able to create your own recovery disks. Hope this helps. Thank you.
Sep 28, 2008 | Toshiba Satellite A105 Notebook
Laptop
Sir,
Dec 02, 2007 | Toshiba SATELLITE PRO 6100 15 inch SXGA...
Toshiba a105 recovery disks display
well...if you are enrolled at a university you can get a student version of windows at an unbelievable discount.
Oct 02, 2007 | Toshiba Satellite A105 Notebook
Open Questions:
See all Toshiba Satellite Pro 6100 Notebook Questions
Toshiba Satellite Pro 6100 Notebook Logo
190 people viewed this question
Top Toshiba Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
