Unit is leaking from front trying to check inside components need to know how to get inside
SOURCE: Need to remove the front panel of front load washer
you will have to remove the rear panel in order to remove the front panel. The bolt and clamp are inside the front panel.
SOURCE: cant find access to the drain pump?
If it does not have an access panel on the lower front, you have to take the entire front and top off. it is under the drum on the right side. A lot of times it is the strainer clogged at the pump. Hope that helps.
SOURCE: will not drain pumps little water
Hello,remove the lower front panel....screws to remove are #19 and the panel #18 will drop down a bit and forward to come off.
sometimes coins,zippers,lint,bra under wires will get caught/jammed in the drain pump assembly and stop it from running/working.The hoses can be removed from the pump to check for any foreign objects or the
pump (the part where the pink and white wires are) can be totally removed by unclipping the wire harness and removing the two "5/6" bolts to check the pump assembly itself,The pump can be taken apart to check inside....if needed.The pump assembly is in the front right corner......
Thanks
SOURCE: Won't drain. Blinking pause. Won't
Hi.
You need to check the drain filter, which is directly connected to the pump. That is the place where you usually find blockage. The filter or coin trap is located inside the drum. See the schematic below:
If that is not enough, then the drain pump access is located in the front side of the machine, hidden behind the trim at the base. The kick panel is held to the washer's frame by screws:
After removing the panel you will Be able to access the pump. Have a container ready to collect water that will come out through the hose.
DISCONNECT POWER before starting the job.
Here parts diagrams: GLTF2940FS1 - parts catalog
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
