Computers & Internet Logo
Leahmarie Posted on Feb 02, 2013
My compaq presario c500 laptop keyboard isn't
Anonymous
Level 1:
  • Contributor 26 Answers
  • Posted on Feb 03, 2013
Anonymous
Contributor
Level 1:
Answers
26
Questions
0
Helped
4117
Points
78
Only one way change the keyboard with new one. or use ans extrnal usb keyboard
5 Related Answers
listeur
Grant Cameron
  • 88 Answers
  • Posted on Nov 24, 2007
SOURCE: Keyboard typing wrong characters
turn off the keylock on boot- this is an option in the bios. also you might be able to use the fn key and turn it off manually
Anonymous
  • 16 Answers
  • Posted on Jan 13, 2009
SOURCE: What Fn Key enables the keyboard to type letters instead of #s
use fn key plus numlk key
Anonymous
  • 61 Answers
  • Posted on Mar 18, 2009
SOURCE: my laptop keyboard is typing different letters and numbers
It sounds like your keyboard is starting to go. Try plugging a usb keyboard and using that. If your keyboard needs replacing, it may be around $50, but that will depend.
Wahs Team
  • 215 Answers
  • Posted on Sep 07, 2009
SOURCE: When I type letter keys, numbers come up with the letters
check your keyboard: T and 5 are relatively close to each other. Try to clean the area under keyboard buttons especially these two buttons. may be it can help you.
leecom72
Lee Hodgson
  • 4810 Answers
  • Posted on Sep 14, 2009
SOURCE: compaq presario cq60 keyboard
If the problem is intermittent then the problem could just be foreign objects like crumbs and hair that's trapped under the keys.
Turn the laptop off and stand it on it's side with the lid open. Get a soft, dry paintbrush and brush the keys, gently tap the keyboard in various places with the back of the paintbrush to help dislodge anything that's trapped.
Once your satisfied all the keys are clear turn the laptop on and see if it has made any difference.
If it has not then you may need to replace the keyboard.
Good luck.
How to clean the fan of my computer
Regular maintenance of your Compaq Presario laptop helps to keep the machine running properly.
Keeping the fans clean is especially important, because the fans blow out hot air and bring in fresh air to cool down the laptop.
Fans attract dust, however, which can slow them down, resulting in a hot laptop.
If the laptop overheats, vital parts can cease functioning altogether.
Consequently, keeping your laptop's fans clean is crucial.
or you might want to remove it to get it clean
HP Presario C500 is a laptop that, like most other laptops, requires a clean, functioning fan in order to work properly.
If your fan is too full of dust to function properly or needs to be replaced because it is no longer working, then your computer could be in danger of overheating and crashing.
Instead of having to purchase a new laptop because your C500's fan has failed, remove it and clean the fan or replace it with a new one.
Turn off your computer and unplug all the cords and cables from it, even the power cable.
Turn the laptop over and remove the battery, then remove all the screws at the bottom of the computer with a Phillips-head screwdriver.
Remove the two face plates from the bottom of the computer and you'll see the hard drive and RAM below.
The face plates will come out easily once the screws are removed.
Remove the two screws holding the hard drive in place and then lift the hard drive out.
Remove the screw found directly below the hard drive.
Turn the laptop over again and pop off the keyboard.
If all the screws at the bottom of the computer where removed, then the keyboard will come right out.
Remove all the screws underneath the keyboard and case and then lift the case enough to access the fan assembly in your HP Presario C500.
Unhook the cable coming from the fan into the motherboard and remove the screws holding the fan in place, then pop the fan out of the computer.
Hope this helps
How to clean the fan air
or Remove an HP Presario C500 Fan Assembly to clean it
Hope this helps
Compaq presario v6000 keyboard not working properly
seems that the number lock is on for that keyboard look for Numlock and see if it's lit up and if so, toggle that. those keys are the numbers 0 through 9 on that keyboard. that should do it.
1helpful
I need a new a new fan for presario c500,where can I buy it?
I put 'Presario C500 Fan Assembly', in my browser search bar, and this is one of the many search hits,
http://www.getpartsonline.com/409073-001.html
Regards,
joecoolvette
1helpful
Broken keyboard keys on Compaq Presario C500 laptop
yes, all laptop keyboards can be replaced. do you have the manual for the laptop? it shows you have to remove it and take it apart. or you can download the manual from their website. you can buy a used keyboard from ebay. I don't think they are thay expensive.
Good luck
1helpful
2answers
Compaq presario C500
if you don't have driver disc,then you can find it in driver databases
3answers
Replacing Keyboard on Compaq c500
You have to send it in for repair. You need speical tools to get the keyboard out.
Loose keys
you can use a usb keyboard instead of the laptop keyboard until you find a replacement, there are fairly cheap
good luck
Map keyboard on Compaq presario c500
Has everything changed, or just some of the keys?
Make sure the NUMLOCK is not engaged.
Grand Canyon Tech
Grand Canyon Tech
