Toshiba notebook NB505-N500BL is making clicking noise, & won't start up. It only shows a black screen with white words saying operating system not found
Posted by gmen72 on
  • Computers & ... Master
  • 18,666 Answers
Hard drive failed, replace it
Posted on Feb 02, 2013
Need to reset toshiba nb505 to factory specs
RTM yet, read the manual
or ask Toshiba this,
I guess you mean reset the unstated, OS back to day one new as toshiba had it?
right. the manual tells you to make recovery disk.
and my guess you never did day 1 new. that it?
if yes, then you get to buy windows again.
8 year old PC so says the the manual.
so is not w8 nor w10 there,
it seems W7, right?
so buy W7 and install it.
or try w10 for free for 30 days, see if it runs,w10 does not like PCs too old.
page 50 shows " how to recover to the out of the box experience"
day1, all your data gone, all your apps gone. RTM or ask at toshiba forum we are not toshiba at all, not even close.... ok?
https://www.manualslib.com/manual/203382/Toshiba-Nb505-N500bl.html?page=20&term=recovery&selected=1
Sep 08, 2018 | Toshiba Computers & Internet
How to stop my mini Toshiba NB505 from flickering
sounds like a loose lead connecting up the screen, if you take it apart, look for a flat strip with metal lines on it going into a socket in the top half, from the bottom half.
Sep 11, 2014 | Toshiba Refurb mini NB505-N500bl Intel...
Toshiba nb505 atom bluetooth driver
1) Go to the following link:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2861099&rpn=PLL50U&modelFilter=NB505-N508BL&selCategory=2756709&selFamily=2336267
2) go down and select your operating system3) click where it says "all categories" and select blue tooth.
4) two download links will appear. Download and install the second one first (driver package). Then if you have windows 7, download and install the first one (blue tooth stack) but only if you have windows 7. no need to install "BLUETOOTH STACK" if you have windows xp.
i hope i was helpful.
Sep 07, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
Toshiba L300 crash and recovery disk will not install message says 'no RAID'
From your description the hard drive has issues, I recommend having it tested for possible replacement.
Jul 20, 2012 | Toshiba Satellite Pro L300 Notebook
How do I reset the BIOS password for a Toshiba NB505-N500BL?
You can do this from the Bios itself. Depending on your system press either F2 or DEL during start up before the windows logo is displayed. Go to security and you can change the password there. You will have to have the current password in order to do this.
Jul 10, 2012 | Toshiba NB505-N500BL 10.1in Netbook...
Tighten nb505-n500bl hinge
Laptop hinges cannot be tighten, there are no adjustments available.
The hinges need to be replaced.
Replacing a hinge, or both of them, isn't very tough this WEB site shows how it is done.
http://www.insidemylaptop.com/replace-br...
Feb 24, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
My toshiba NB505-N500BL WILL NOT TURN ON
Your motherboard or battery may have died. Have to repairman check it for this.
Sep 24, 2011 | Toshiba NB505N500BL 1 GB Hard Drive
Are there any instructions for replacing the LCD screen on a Toshiba Mini Notebook NB505-N500BL?
Youtube has lots of them.
Here's a really good one for a Dell.
http://www.youtube.com/watch?v=hoc_ZuU7G-I
Some screens are only $20.00
If this does not answer your problem let me know.
Aug 13, 2011 | Toshiba Computers & Internet
I need help with my daughter's Toshiba netbook.It goes to a screen that asks me to start up Windows or try to fix the problem. When I click on either one, it does some files gathering, but then nothing...
What you can do is you can try setting your computer to do a system restore in safemode
1. Shutdown the computer wait for 5 seconds and Turn the computer back on
u
2. the minute that you see the Toshiba logo pops up keep on hitting the F8 key like a typewritter
3. It will give you a black screen with white writtings that says "Windows Advance Options Menu"
4. Highlight using the up or down arrow key on Safe Mode Press Enter
5. Login your Windows password
6. Click Start --> Search Programs or Files and type System Restore
7. Select the Recommended Restore point when the computer is working keep on hitting Next and you are Set
Jul 18, 2011 | Toshiba Lime Green 10.1" NB505-N508GN...
Black screen , loud alarm noise
The problem of your laptop is in the RAM just clean the RAM by wiping an eraser of the printer or a rubber. To remove the RAM open the back of your laptop where the RAM was inserted.
May 28, 2010 | Toshiba Satellite A100-S8111TD Notebook
Computers & Internet Logo
k24674
