Password and username received from isp woreked well. then red light came on and all connectivity lost.
Check the Ethernet wire's connection between your modem and router.
Check all physical connection..
Hard reset your netgear router.
**If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: My SMCWBR14T-G wireless router cannot connect to the internet..
What is your OS?
Are you connecting with a wire or without?
Are you using encryption?
Post your ipconfig info:
Start Run cmd
ipconfig
Enter to copy, paste into this window
In most cases, it is best to set the router to defaults and start over.
SOURCE: Zyxel internet configuration doesn't accept passowrd/username
AOL have a couple of special requirements for the username and password which can catch you out.
Here are a couple of pages which might help:
1. AOL screenname requirements
2. AOL password requirements
This issue caught me out while ago. However, this may not be your problem, so please come back if this answer doesn't help.
SOURCE: lost username and password for router
To reset the password on the router, switch it off, press and hold the 'reset' button whilst switching the power back on. Keep holding the reset button until all of the LAN lights blink, and your router will be reset back to the way it was when it left the factory.
This only applies to get round the settings installed on the router. You will have to input all the telefonica settings again so that your router can connect to the internet. Resetting the router will not solve any problems regarding telefonica passwords or user names - for this, you (or the account holder) will have to contact telefonica directly.
I hope this helps you.
SOURCE: DIR-300 router and broadband ISP connection,is NAT possible?
With a cable broadband connection, the cable line comes into the cable modem. The cable modem does the work changing the cable signal to a network connection and sends an I.P. address to the computer. With some cable internet providers you can hook the network cable into the in port on a router, wireless or wired, then hook up computers to the router. At this point the router gets the IP from cable and uses it's own IP routing for your internal network. Some broadband providers control your access by the computers mac address which registers with the vendor. If this is the case then the easy way to make it work is to get a router which can clone a mac address so the vendor still sees the same mac address.
SOURCE: I have a NetGear Wireless Router which wont connect to internet.
Verify that you can connect to the internet without the router by hooking the cable from the dsl modem to your computers NIC.
If you can connect to the internet that way the problem is with the router. press and hold the reset button on the back of the router to reset it to the factory settings. (this just makes it easy to determine the problem) if this corrects the problem you can setup your security again
Testimonial: "I received great help! I got speedy replies and great information at a level I could always understand and proceed to work with. Great first experienc"
I understand that you are not able to connect to internet through DG834Gv5 as the internet light on the router is RED. I would suggest you to reset and reconfigure the router using the below steps:
RESET:
1. Press and hold the Wireless On/Off and WPS buttons simultaneously until the Power LED turns red (about 6 seconds).
2. Release the Wireless On/Off and WPS buttons. The LED blinks red three times and then turn green when the router has reset to the factory default state. Wait for the router to reboot.
CONFIGURATION:
1. Connect the cable/phone line coming from Internet Service Provider to the WAN port of the router (isolated port).
2. Connect the computer to the router using any one of the 4 available ports.
3. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
4. Access the router's GUI by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
5. Login to the router (username = admin password = password unless you have changed it).
6. Click on 'Setup Wizard' at the top of list from the left menu.
7. Select Yes and click Next.
8. It should give you 'PPPoA Detected' and then click on next.
9. Enter the login and password of the ISP and then click on Apply.
10. Once the settings are updated click on 'Router Status' and click on 'Connection Status' button (at the bottom of the page).
11. Click on Connect button.
12. Connecting to server should show 'Connected'.
13. If you receive 'CHAP authentication failed', close the 'Connection status' window and click on 'Basic settings'. Verify the login and password for ISP and apply the setting again.
14. Open up another browser window and try to access internet.
Please do visit http://kb.netgear.com for any technical queries regarding NETGEAR products.
I hope this information allows you to resolve this issue.
Regards
Anand
