2006 GMC 3500. DVD, CD, AM/FM, all sound incredible. Subscribed to xm and did everything they said - set to preview channel for 15 minutes while truck sat in one spot. All the stations programed in perfectly, can see what songs are playing, etc... Problem is that there is no sound whatsoever. It is like it is dead. Can swith over to CD or radio and everything is great. Called XM and they said it is a factory/dealer issue. Any thoughts??
Thank you. AARON
Never had any sound on the preview channel at all from the time we got the truck and now no sound on any of the xm channels.
SOURCE: my delphi xm is frozen
I pressed the volume + and mode/power button simutaneously and this seemed to reset the unit and allowed the download to progress and allow the unit to power off
SOURCE: xm will not work
i understand that you're only getting preview channels..and had the radio for almost 3 years....yes, they might be correct that your radio was broken already...but, have you ever asked them to refresh the signal into your radio? If you want you can do it online at www.refresh.xmradio.com all you to do is to key in your 8-digit radio i.d(can be found on ch. 0) then click submit...it'll give u the activation instructions...that u need to follow faithfully..if this won't work..i'll get back to you next week..Godbless!
SOURCE: xm radio installation in house
hi there..this will be like a walk in a park...first, in your home kit you should be having the ff: antenna, rca cable(audio cables), power adapter & docking station. We just have to 'placed the radio into the docking station' then we just have to plug in the ff cables into the xm receiver..we can start plugging in the rca cable(one ended connector) into the ' audio out ' of your xm radio...the other ends of the rca cables should be plug in into the 'audio in'(at the back/infront of your sound system)...plug in the antenna in the 'antenna out' of your xm( the antenna should be placed into a south facing window and not being block by tall trees and buildings outside)....plug in the power source and turn on the radio....if you got it right you should now be getting the prev.channels/emergency allerts...u can call xm to send a refresh for you to get the complete channels..or you can do it online by logging into www.refresh.xmradio.com(if the radio was already activated) if not, you have to call xm radio to activate it..enjoy listening to xm..Godbless..
Hold the volume button down and press the mode button at the same time.
