GE Freezer  14.8 Cu. Ft. Manual Defrost Chest Freezer Logo
A
Anonymous Posted on Feb 01, 2013
I have a bfeq50 model freezer it just went out on me after a month how can i fix it
3helpful
How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
Gene
Both springs on lid broken. Lid won't stay up.
Whatever is on the shelf (parts that have not sold yet) is your best bet. Someone in the USA has to have em cause it hasnt been that long out of business.
here's one place to start ( i couldnt get thru)
AJ Madison
1416 38th Street
Brooklyn, NY 11218-3614
Phone: 800-570-3355
718-532-1800
Phone: 800-570-3355
718-532-1800 Fax: 800-570-7805 E-Mail: [email protected] Appliance
Parts Store:
800-378-5177
Appliance parts store:
1800- 378-5177
hope this helps
2answers
Fisher and paykel e521t icing issue
should be a hose going down to drain pan, check it, could be plugged, or compressor on way out an controll not workin prop.
Jan 04, 2010 • Freezers
Freezes for 7 to 14 days then just quits!
hate to tell you but your compressor is going out on your freezer ,,, i'd look for another freezer.
Larry
Fridgidaire upright freezer alarm FFU2065FW
If the compressor is not running but you do have power to the refrigerator, there may be a problem with one of these:
The compressor,The Thermostat,The overload, relay, or capacitor,The defrost timer,The condenser fan motor.
Try to troubleshoot each of these componet one after the other using eliminating method.
That may solve your problem.
2answers
Freezer quite working after an electrical surge in area...
tell her to change the rely on the compressor if there is an appliance parts store tell her to get a three in one reley and follow the instructions that come with it
May 25, 2008 • Freezers
Kenmore Freezer Model 23041
I have an upright freezer which temp was unstable. The coils were frosted up, and the circulating fan was unable to pull air across the cooling fins.I defrosted the unit, cleaned it up, and turned it back on. Worked fine until it frosted up again. The unit was a no frost model. I had to have it serviced, and one of the defrost sensors was bad. No problems since this was fixed.
FREEZER NOT WORKING
that is very possible if the fan and compressor are running. the best thing you can do is call maytag. its only 4 months old and is there problem to fix. Good Luck
Top GE Freezers Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a GE Freezer Expert? Answer questions, earn points and help others
