1.), Pump may be bad. Check voltage to water pump in Spin Cycle. If you have voltage at the pump, but it does not run, replace the pump.
2.) If you have voltage to the water pump, and can hear or feel it running, cut power off, and remove the boot which is directly below the wash bin. The boot empties into the water pump. You will need long needle nose pliers or better, use water pump pliers to remove the straps holding the rubber piping to the pump and the boot. Remove debris from the boot, i.e., bobby pins, coins, socks, pens, keys, etc.
3.) If no voltage comes to the pump in spin cycle, you may need a new timer.
4.) Install a new belt on the motor pulley. You will regret not replacing the belt later.
