Question about Toshiba E Studio 230 280 Copier
Need EFI net work cord for e28 toshiba copier
EFI 10 network card for e28 copier to use it as a net worc copier
MightyMikeJr
    Master:
  • 409 Answers
Have you tried resetting the copier by unplugging it and waiting a few moments? If you problems persist check us out online for all your copier repair or Copier Rental needs
Posted on Jul 13, 2017
Amber light is flashing on network card
Switch off the printer, re connect the net work cable, switch on the machine & wait till ready mode comes.. Go to administration on control panel, select configure device,select configuration page, print,, total three print out will come, in that see the IP address.. If any IP address showing, ping that IP from system, if its pings, reload the drivers once again.. check for the print. If no IP adress showing in configuration page, try with another net work cable & try above said exercise.. Even no luck, remove formatter from the slot & re-fix once again & try... Even no luck.. it might be network port faulty. If its warranty contact HP support for free replacement.. If no warranty purchase HP620n or higher version of zetdirect card(net work card) install it... But take service engineers suggestion before replacing the network card..
Aug 01, 2012 | HP LaserJet M4345 MultiFunction Printer
Codigo np para poner otro shi
net work card went bad replace eather net card.
Mar 10, 2011 | HEWLETT-PACKARD P2015D Formatter Board -...
Some letters don't worc
Laptop.... eh??
a bit problematic..... I guess u shudn't jus take any chances unscrewing ur laptop to screw urself up........!!! ;)
but, the prob is that ur keys cannot connect to the keyboard circuit wen they r pressed.......
contact a computer repair shop..... they will be able to help.....
Jul 06, 2009 | Dell 0Y3740 Keyboard
Does dell dimension 2400 have ethernet card inside?? Basically when dell made the dimension 2400, did the put an ethernet card inside. Or do i have to buy one and install it myself? I have this Broadcom...
The 10/100 Integrated controller is the onboard network card
That basically mean yes it does have a network card built onto the motherboard.
If this helped please leave a Rating
Best of luck
Blazamane.
Jan 08, 2009 | Dell Dimension 2400 PC Desktop
My phone says "service unavailable" help!!!!! No incoming or outgoing calls can be made
Service unavailable mean you don't have any network. Check with your service provider if they have barred your service or not. This has nothing to do with mobile phone. If there will be no services from your service provider you will not be able to call or send message or receive calls.
Summary: Check once with your mobile service provider.
Dec 28, 2008 | LG Shine 720 Cellular Phone
Nokia net 10 unlock code
now a days mobile unlock very simple,because lot of unlocking source avail across the globe just reach here and find your unlock code http://www.mobileunlocksolutions.com/
Dec 25, 2008 | Nokia 1600 Cellular Phone
First 30 pages of a print run after 24hrs idle are blank
don't upgrade the xp, it runs a limited version to ensure that the command workstation works ok. A reload is probably in order to start again. Any updates can generally be found on the xerox website, and installed via command workstation
Aug 09, 2008 | Xerox DocuColor 12 Color Copier
How to improve my internet speed
hi Prem,
If you are using 256 Kbps broadband and you have installed 10 PC in ur network with Star topology then i dont think it shold be creating the problem. Star topology holds best compatibility in a small network.
The Problem would be causing because of your network card.
Network Card (NIC) plays most important role in ur network for transmitting and receiving data efficiently and fastly.
So you would need to check out for ur NIC card first i.e what catagory of NIC are u using?
You need to upgrade ur NIC in the server and also in ur client's PC.
Different catagory of NICs are-
1. 10 Mbps
2. 10/100 Mbps
3. 100 Mbps
It is recommended to use 100 Mbps NIC card for best performance in ur network. This will surely improve your net speed.
Another cause of ur slow speed is your broadband speed. If you have Cyber Cafe then you should upgrade with atleast of 512 Kbps of broadband speed in your network for better performance.
And use a good broadband service provider who are using good spectrum and bandwidth.
Like - Reliance, Airtel, Sify etc. (for India Only)
The given solution will defenately help you to improve your Network. e-mail me you acknowledgement on - [email protected].
Aug 01, 2008 | Microsoft Windows Server Standard 2003 for...
Adaptor Cable for NetGear FA410TX from PCMCIA Card to Cat 5
You can try
http://www.bixnet.com/10pcmcinetpc.html
http://store.customcableconnection.com/cpn-gn100t.html
Also, since it appears to be a standard 15 pin connector, any standard 15 pin should work.
Compatible cards are:
Linksys 10/100 LAN Adapters:
  • PCMPC100
  • PCMPC200
  • NP100TNetGear:
  • FA410TXD-Link:
  • DFE-530TX
  • DFE-650
  • DFE-650TX
  • DFE-660TXMulti-Tech:
  • MT10100ZLX/ENetwork Instruments:
  • FE-6430ATrendNet:
  • 10/100 (RJ-45)Best Data:
  • MT10XL X/E
Jun 11, 2008 | Computers & Internet
Toshiba E Studio 230 280 Copier Logo
83 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
Timothy Van Der...
Muntejaya Ginting
Muntejaya Ginting
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
