Question about Acer Aspire 3102WLMi Notebook
I had a error message come up on acer 3102 which said to restart computer, something to do with installing something although I hadnt, I turned it back on and it lights up, says acer and the screen goes black. can anyone help?
Posted by r merryman on
  • Acer Master
  • 18,397 Answers
You are going to have to use restore to see if you can bring it back. Press and hold F8 immediately after you start it and see if a menu comes up that lists options to restore the computer. You need to be careful though because a full restore will wipe the drive and everything on it.
Posted on Feb 02, 2013
5 Related Answers
Anonymous
  • 56 Answers
SOURCE: acer aspire 4520 -5458 gets a blue screen error message....
your harddrive has gotn fucked up or some thing try install ing and formating it from a cd if that doesent work order a nwe harddrive
Posted on Jan 02, 2009
Anonymous
  • 66 Answers
SOURCE: Acer 5315 goes to black screen with cursor
If it's only 5 months old, then it's still under warranty. Right now, I'd advise taking it back to have it fixed instead of taking it apart to replace hardware and possibly voiding a warranty.
Posted on Feb 16, 2009
Anonymous
  • 92 Answers
SOURCE: Black screen NTDLR Press any key to restart
It sound like your hard drive has crashed. There is no easy solution to your problem. Here are a couple solutions. You need to run a "chkdsk". It will scan and fix file problems on your HD. To do this you can either download a boot disk like "Ultimate boot disk" or you can take the HD out of your laptop and attach it to another computer. Neither of these are easy, for the boot disk you need to have software that can burn a "iso image" to a cd and to attach the HD to another computer you have to have the proper adapter. I would be happy to walk you through either one of these, just let me know. The easist thing to do would be to contact Acer and get recovery cds then go buy a new hard drive. I would take the old one to the store, to be sure I got the right replacement HD.
Posted on May 27, 2009
joecoolvette
joecoolvette
  • 5660 Answers
SOURCE: black screen on acer 242lc lights come on power up
You indicate that the lamp for Power On comes on? (Light bulb icon)
What about the harddrive activity lamp? (Media Activity icon. Looks like a book. Third icon going right, from Light bulb icon)
Is this lamp lit up? (May flash dim to bright) This indicates the harddrive is working.
Yes?
Do you have a floppy disk in the floppy disk drive? Remove it.
No floppy disk? Media Activity icon lamp is working?
Try increasing the Brightness. Hold the Fn key down, (Function key), and press the Right Arrow key.
No?
See if the LCD screen display has accidentally been toggled over to an external display. Hold the Fn key down, tap the F5 key once.
No?
Then it's time to get technical.
The following is not designed to confuse you, nor make it seem like, 'I'm all that, and a bag of chips'
It's a Flow Chart I have used in the past, plus techniques for finding laptop display problems.
[I no longer require using this flow chart]
Do you have an external VGA monitor you can connect for a test? Your laptop has a VGA connector on the back.
[Your VGA connector is in the center, on the back of your laptop]
(VGA monitor looks like a TV. It is a Cathode Ray Tube. CRT)
This is what a VGA connector looks like,
http://en.wikipedia.org/wiki/VGA_connector
(Top photo on right)
Connect the VGA monitor first, THEN, power on your Acer laptop.
Now turn the power on the VGA monitor to On.
You have to toggle your graphics over from your LCD screen of the laptop, to this VGA monitor.
To do this you hold the Fn key down, then tap the F5 key once. (A VGA monitor takes a second, or so to 'Come to life'. Wait a few seconds, see if the VGA monitor comes on. If not, hold the Fn key down again, and tap the F5 key)
Now, do you have graphics on the VGA monitor?
Yes?
Do you have a dim screen?
Try using the Brightness control of the VGA monitor to increase.
Doesn't work?
Then you have a bad Backlight, or a bad Inverter.
(An Inverter supplies the correct power to the LCD screen, and the Backlight.
The Backlight is comparable to a Fluorescent tube, used for normal residential, and commercial lighting. It is a Cold Cathode Fluorescent Lamp. CCFL. The LCD screen cannot be seen without this Backlight bulb)
Requires replacement of these two components.
A Backlight bulb is cheaper to replace than an Inverter. A Backlight bulb is also MUCH harder to replace than an Inverter.
The Backlight bulb is located within the LCD screen itself, which requires dismantling the LCD screen to replace it.
The Inverter is a component that is accessed much easier.
Upon removing the LCD screen from the laptop, then removing the bezel that goes around the LCD screen, the Inverter is located at the bottom of the LCD screen.
I state that both components should be replaced, because I have found that when one goes out, the other is usually not far behind it.
Do not have a dim screen?
Then the connectors for the wires, that supply the video signal, and power to your LCD screen, may be loose.
OR,
1.It could be those wires are broken
2.It could be a bad LCD screen
3.Could be a bad connector on the motherboard, for the wire's that deliver signal, and power to the LCD screen's connector,
or the matching connector on the LCD screen, for those wires.
Do not have graphics, (images), on the external monitor?
Then you have a bad graphics chip on the laptop's motherboard.
Requires replacement of the motherboard.
The above is stated, so that you will know what may be happening with your Acer Travelmate laptop.
It is for information purposes.
It is not a recommendation, nor advisement to repair the laptop.
The only true way of finding out what is wrong with your laptop, is to take it to a competent computer repair shop, and have it diagnosed by a professional.
Posted on Sep 18, 2009
Anonymous
  • 84 Answers
SOURCE: my acer aspire one notebook says 'a disk read
Disk is dead. You need to replace disk and reinstalla Operating System.
Posted on Oct 19, 2009
Acer az3730
press f8 during the boot up process then select the last known good configuration
Feb 10, 2014 | Computers & Internet
Resetting to factory settings trouble
You are caught in a loop. Have no recourse other than to use your restore disks and attempt a repair or new installation.
Sep 06, 2017 | Acer Aspire Z5600 PC Desktop
Acer Notebook was getting slow then i try to reset then after the process it restarted then said "Setup is starting services". It shows a error message "The computer restarted unexpectedly...
A scratched cd/dvd can have errors causing the install to fail. Use a clean cd/dvd install disc to fix it.
If you are trying to install directly from the hard drive then a malware infection could have corrupted or damaged that part of your hard drive. Install windows from the cd/dvd disc for your computer.
Aug 28, 2011 | Acer Computers & Internet
The Mouse and Keyboard are frozen and will not work. Pressed unlock mouse button but did not respond. What do I do?
Restart by pressing the Start button and keep pressing until it shuts down. Then restart.
Here is more on this subject:
http://www.computing.net/answers/windows-xp/hp-pavilion-is-frozen/162636.html
Jan 07, 2011 | HP Pavilion dv9000z Notebook
Acer 5100.  During a Full Restore this error message interupts the restore: (The computer restarted unexpectedly or encountered an unexpected error. Windows installation cannot proceed. To install...
Since you cant start it using your recovery disk, you need to bring it to a service center because the are going to take out the hard drisk and connect it with other computer so they can do the restoration or reformating
Nov 08, 2009 | Acer Aspire 5100 Notebook
Acer e525 network adapter doesn't work(NONE of the drivers works)
Access "Device Manager".
Select the device.
Click to "uninstall" it.
Restart your computer.
Vista should automatically "find new hardware", and install the correct driver.
If not, tell us what error-message(s) you get.
Sep 19, 2009 | Acer eMachines 520-2890 Notebook
I am doing a clean install from the recovery disk, eveything went fine, all the files copied over, but when it rebooted a message window popped up and said "Windows setup cannot configure Windows to run on...
There might be a bios setting that you have too set for the recovery mode. If you can get into the BIOS then check to see if there's a setting for recovery. You can also try at boot up (before the Windows error) to hit Ctrl-F10.
Apr 11, 2009 | Acer Aspire L100 PC Desktop
Error warning when first turning laptop on
If you just bought it from a store, take it back and they should fix it under warranty.
Mar 07, 2009 | Acer Aspire 5735 Notebook
Acer aspire 4520 -5458 gets a blue screen error message....
Jan 02, 2009 | Acer Aspire 5100 Notebook
Error Tab
Turn off the, or better yet uninstall, the Acer Screensaver. Something you installed, possibly a screensaver program? has corrupted the Acer screensaver causing that error message. That add-on screensaver is notoriously buggy anyway.
James Smith
A+ NET+ Server+ M.C.S.E. CCNA
Sep 09, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire 3102WLMi Notebook Logo
Ekse
Lee Hodgson
Lee Hodgson
Gustavo Ortiz
Gustavo Ortiz
