2005 BMW X5 Logo
Stuart Duff Posted on Feb 01, 2013
My screen on my 05 plate X5 which displays all the features, radio, television, telephone etc.. is not focusing and going fuzzy like if a tv had to be tuned, can anyone help here please , Stuart
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 18, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
185
Points
Take a look at pixel repair ribbon
2 Related Answers
Anonymous
  • Posted on Nov 27, 2008
SOURCE: 2003 BMW X5 radio display lights
BMW has a free fix for that! It's a factory recall with the pixels. Check with your dealer.
Anonymous
  • Posted on Aug 25, 2009
SOURCE: X5 dead satnav/radio display
I had the same problem with the suspension on an o2 X5 Sport,it was the stabiliser pump in the rear,Range rover is the same pump and is cheaper than the BMW part,they also do an exchange unit.
2helpful
2answers
How to unlock radio locked on a 2005 c6 corvette
dealer with vin or vehicle and proof of ownership
Head bolt torque spec 05 bmw x5 4.4l
  1. Cylinder Head - AutoZone
    www.autozone.com/.../BMW-X5...05/.../Cylinder-Head/_/P-09...
    AutoZoneBMW X5 2000-05 .... Cylinder head bolt tightening sequence-4.4L & 4.6L engines. To install: ... Torque the bolts in thesequence illustrated in 3 steps as follows:.
Cd Code need code for am fm / CD /cassett player purchased at junk yard out of a 2000 Suburban and putting it into my 2010 Chevy Colorado which has only basic am / fm radio? How do I get past "locked"...
That is a security "feature" on GM radios to deter theft. The following instructions has had sucess with other GM vehicles. If not, only a dealer has the equipment to get past lock screen.
This works on vettes with theftlock. Try it on the tahoe and let us know....
The following procedure will give you a new code that you can use instead of your personal code. Using this new code, you can "unlock" your radio and then "re-lock" it with a new code if you wish. Prerequisites: The radio must be in LOC mode NOT in INOP mode. Let me explain. If you have activated the Theft-Deterrent feature of your radio and loose power, the radio goes
into LOC (theftlock) mode. With the ignition on, you must use the MN and HR buttons to enter you personal code in order to unlock it (The instructions are on page 3-27 in your Y2K Owner's manual). If you fail to enter the correct code eight (8) times, the radio goes into INOP
mode. You have to wait an hour with the ignition on before the radio returns to LOC mode (go for a long drive somewhere).
Procedure: 01. Turn the ignition ON (The radio displays LOC)
02. Hold down the Radio Presets 2 and 3 buttons for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down. Don't take forever, fifteen seconds max before the next step.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1 800 537 5140
08. Press 1 then # (pound). You'll hear "Invalid Code, try again"
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by * (start)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now "un-locked" and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner's manual. Use the code from STEP 11 instead of your personal code. Note: This tip originated from LOTZAHP, Austin TX (credit must be given where credit is due). I verified it on an Y2K C5 with a locked radio - mine.
http://chevroletforum.com/forum/tahoe-suburban-25/help-radio-locked-8220/
1helpful
My TT was imported new from Japan....Has AMAZING video and sound system unfortunateley its all Japanese to me!! The manual that comes with it is about an inch think...Its got built in Navigation system...
I know you can that you can change this by simply hooking up a scan tool for specific year. There are language options accessible for situations like this. Here is a sample of what can be changed using VAG 5052 or equivalent scanners.
Coding
  • 0?xxxxx: Model
    • 1 = Lamborghini
    • 2 = Audi A3 (8P)
    • 3 = Audi A4 (8E)
    • 4 = Audi A4 Cabriolet (8H)
    • 5 = Audi A6 (4B)
    • 6 = Audi TT (8J)
    • 7 = Audi R8 (42)
  • 0x?xxxx: Treble Speaker Monitoring inactive
    • 0 = Front Treble Speaker Monitoring inactive active (NOT Audi A4 Cabriolet)
    • 1 = Front Treble Speaker Monitoring inactive inactive (ONLY Audi A4 Cabriolet)
  • 0xx?xxx: Sound Characteristic
    • 0 = Sound Characteristic linear
    • 1 = Audi A4 (8E)
    • 2 = Audi A6 (4B)
    • 3 = Audi A4 Cabriolet (8H)
    • 4 = Audi TT (8J)
    • 5 = Audi A3 (8P)
    • 9 = Sound System
  • 0xxx?xx: Telephone/Telematic
    • 1 = Telephone not installed (Remote Feed Voltage for Microphone active)
    • 2 = Base Plate (Temic - Remote Feed Voltage for Microphone inactive)
    • 3 = Base Plate (Cullmann - Remote Feed Voltage for Microphone inactive)
    • 4 = Base Plate (Nokia - Remote Feed Voltage for Microphone inactive)
    • 5 = Telematic Europa (Remote Feed Voltage for Microphone inactive)
    • 6 = Telematic US (Remote Feed Voltage for Microphone inactive)
    • 7 = Base Plate diagnostic capable with Comfort Control
  • 0xxxx?x: Equipment I
    • 1 = Tuner not installed
    • 2 = Digital-Radio installed
    • 3 = Satellite-Radio installed
    • 4 = Satellite and Digital-Radio installed
    • 5 = Analog Input (AUX) installed
    • 7 = Satellite-Radio & Analog Input (AUX) installed
  • 0xxxxx?: Equipment II
    • 1 = TV-Tuner/CD-Changer/Multi-Function Steering Wheel not installed
    • 2 = TV-Tuner installed
    • 3 = CD-Changer installed
    • 4 = TV-Tuner and CD-Changer installed
    • 5 = Multi-Function Steering Wheel installed
    • 6 = TV-Tuner and Multi-Function Steering Wheel installed
    • 7 = CD-Changer and Multi-Function Steering Wheel installed
    • 8 = TV-Tuner and CD-Changer and Multi-Function Steering Wheel installed
Adaptation Channel 001: Tire Circumference The tire circumference is beeing adapted in "mm".
Channel 002: Wheel Pulse The wheel pulse describes the amount of wheel pulses per revolution.
If value 0 is entered the system calibrates automatically itself after several kilometers and inputs a value.
  • 43 = Audi A3 (8P) / Audi TT (8J)
  • 45 = Audi A4 (8E)
Channel 003: Language (Screen)
  • 0 = German
  • 1 = English (UK)
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
  • 6 = Portuguese
  • 7 = English (UK)
Channel 004: Back-Up Camera
  • 0 = Back-Up Camera not installed
  • 2 = Back-Up Camera installed
Channel 005: Speed Threshold (Video Input)
  • 0 = max. 0 kph or 0 mph
  • 1 = max 5 kph (Standard for Europe)
Channel 007: Options Channel 008: Volume Characteristic Channel 010: Region
  • 0 = Europe/North America
  • 1 = Australia/South America
  • 2 = South Africa
Channel 011: Language (Speech Recognition)
  • 0 = German
  • 1 = English
  • 2 = French
  • 3 = Italian
  • 5 = Spanish
Channel 018: Start Screen The start screen setting has to correspond with the control module coding, e.g. a S3 start screen doesn't work with an A4 coding.
  • 0 = Standard Start Screen
  • 1 = Audi S3 Start Screen
  • 2 = Audi S4 Start Screen
  • 3 = Audi RS4 Start Screen
  • 4 = Audi TT Start Screen
  • 5 = Audi R8 Start Screen
Channel 065: Read Test Channel 066: Self Test Channel 067: CD/DVD Drive
  • 000 - Normal/Eject-Button enabled
  • 001 = Eject CD/DVD (will not be saved)
  • 255 = Eject-Button disabled/locked (Anti-Theft-Protection)
Channel 068: Screen Test Values will not be saved, they only act as initiation for each Test Picture.
  • 0 = No Test Picture
  • 1 = Test Picture: Red
  • 2 = Test Picture: Green
  • 3 = Test Picture: Blue
  • 4 = Test Picture: White
  • 5 = Test Picture: Black
  • 6 = Test Picture: Checkerboard
  • 7 = Test Picture: Checkerboard (inverted)
  • 8 = Test Picture: 64 Gray Scales (vertical Bars)
  • 9 = Test Picture: Special
Channel 069: Display Mechanism
  • 000 = Display closed
  • 001 = Display open
  • 200 = Display half open (Obstacle)
  • 255 = Position undefined
Channel 070: Display Brightness
  • 0 = 0% Brightness (Display OFF)
  • 1 = 20% Brightness
  • 2 = 40% Brightness
  • 3 = 60% Brightness
  • 4 = 80% Brightness
  • 5 = 100% Brightness
Channel 099: Transport Mode Only applies to models without Gateway/Diagnostic Interface for Databus.
  • 0 = Transport Mode inactive
  • 1 = Transport Mode active
Channel 111: Reset
  • To perform a system reset/restart save 1 as new value.
Channel 114: FM Frequency
  • Range: 875...1080
Channel 117: Signal Test (Output)
  • 0 = Fader Center & Balance Center
  • 1 = Fader Front & Balance Left
  • 2 = Fader Front & Balance Right
  • 3 = Fader Rear & Balance Left
  • 4 = Fader Rear & Balance Right
Channel 136: Driver Position
  • RNS-E Basic
    • 03226 = Left-Hand-Drive (LHD)
    • 02632 = Right-Hand-Drive (RHD)
  • RNS-E High/US
    • 00005 = Left-Hand-Drive (LHD)
    • 00013 = Right-Hand-Drive (RHD)
1helpful
05 ford focus ghia/security code/touch screen
hi, if your radio code for example is 8156 you push the
no1 button 8 times then
no2 button 1 times then
no3 button 5 times then
no4 button 6 times then hold down the number 6 button for about 5 seconds and the radio code will store automatacly and start up. hope this helps you regards
2000 bmw x5 nav screen blank. radio works but no
I know this is an old thread, but my 2006 325i Nav screen went bank also, but the radio still played. I noticed the glove box light and trunk light did not turn on also. I was told from mechanics is was probably a CID module for $2200, even though I mentioned the glove box and trunk light light were out and specifically inquired about a fuse. The mechanics never checked the fuses, because I checked my fuses in the glove box and found the fuse 61 marked with a BMW symbol that looks like light bulb was blown. The Nav screen started back up once the fuse was changed.
2004 BMW X5 4.4i Left lights on resulting in flat battery. Car was jump started from another vehicle (Ford Transit van). Everything fine for a few days. Now, intermittently the radio/sat nav goes haywire!...
sounds like your car has the multi function steering wheel, i know on the 7 and 5 series they come out of sync, im not sure why.
its about £75 to get plugged in at the dealers and they reprogram it, sometimes i have had the odd car with a damaged slip ring, it does all sorts of things, 1 in particular kept on beeping the horn,
i would say if u got 1 urs got upset when battery flat.
Apr 22, 2009 • 2009 BMW X5
18helpful
4answers
Oct 21, 2008 • 2005 BMW X5
2helpful
2answers
Ford focus radio display is out
The display of the radio has micro contactes around the edges of the display. The cleaning agent used to clean the dash area could have been damaged. Best reccomandation is to have the unit replaced or taken to a repair shop and have the face plate repaired.
Top BMW Experts
vince
Steve Sweetleaf
Steve Sweetleaf
old marine
old marine
Are you a BMW Expert? Answer questions, earn points and help others
