There is a Wizard in XP for this, which may assist.
- left click the Start button, right click on Internet Explorer - left click the Connections Tab, then the Setup button - left click the Next button, then choose "Connect to the Internet", then Next - Choose the option to "Set up my connection manually, " then left click the "Next" button. - Choose the option to "Connect using a broadband connection that is always on, " or other choice if more appropriate, then left click the "Next" button - Click Finish
hi daphne, follow these steps it shud work The Nintendo Wii system is changing how people game by swinging people into action with their motion activated controlled. Share the fun of this system by connecting to the Internet. Gain more functionality out of your Wii by using it for things like browsing the web, receiving updates, and downloading games. Difficulty: Moderately Easy Things You'll Need: Nintendo Wii High-speed internet access Wireless router Nintendo Wii LAN Adapter Ethernet cable Router or modem PC running Windows XP Nintendo Wi-Fi USB Connector Instructions Connect a Nintendo Wii to the Internet through a Wireless Router 1. Turn on your Nintendo Wii by plugging it into a power source and pressing the power button. 2. Press the "A" button on your Wii controller to continue from the warning screen. 3. Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options. 4. Click the "Wii Settings" box on the right. 5. Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings." 6. Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option." 7. Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected. Connect a Nintendo Wii to the Internet with a Wii LAN Adapter 8. Insert the Wii LAN Adapter into the USB port on the back of the console. 9. Connect an Ethernet cable from your modem or router to the adapter. 10. Turn on the Wii console. 11. Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. 12. Select "Connection Status," then "Connection 3: None" and "Wired Connection." 13. Click "OK" to initiate the connection test. When the test is done you should be connected. Connect a Nintendo Wii to the Internet through a PC 14. Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation. 15. Choose your language and click "OK". 16. Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work. 17. Click on the registration tool on the Windows task bar. 18. Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. 19. Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue. 20. Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect." 21. Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test. Tips
hello. good day. here are procedures i got from e-how.com hope this helps:
Connect a Nintendo Wii to the Internet with a Wii LAN Adapter 1. Insert the Wii LAN Adapter into the USB port on the back of the console. 2. Connect an Ethernet cable from your modem or router to the adapter. 3. Turn on the Wii console. 4. Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. 5. Select "Connection Status," then "Connection 3: None" and "Wired Connection." 6. Click "OK" to initiate the connection test. When the test is done you should be connected.
Connect a Nintendo Wii to the Internet through a PC 1. Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation. 2. Choose your language and click "OK". 3. Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work. 4. Click on the registration tool on the Windows task bar. 5. Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. 6. Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue. 7. Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect." 8. Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
1. Go to samsung mobiles website and download the pc suite version that supports your mobile phone model or if you have the cd of samsung champ run the cd. 2.install it in your computer. 3.then connect your phone through data/usb cable. 4.then choose the option pc suite. 5.access the networking option of the pc suite. 6.chose your phone as the modem and also choose your service provider. 7. Before all these you have to download the settings to access internet through your phone.
You can hook-up your wii to the internet through any of the below method;
* 1 Turn on your Nintendo Wii by plugging it into a power source and pressing the power button. * 2 Press the "A" button on your Wii controller to continue from the warning screen. * 3 Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options. * 4 Click the "Wii Settings" box on the right. * 5 Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings." * 6 Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option." * 7 Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
* 1 Insert the Wii LAN Adapter into the USB port on the back of the console. * 2 Connect an Ethernet cable from your modem or router to the adapter. * 3 Turn on the Wii console. * 4 Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. * 5 Select "Connection Status," then "Connection 3: None" and "Wired Connection." * 6 Click "OK" to initiate the connection test. When the test is done you should be connected.
* 1 Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation. * 2 Choose your language and click "OK". * 3 Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work. * 4 Click on the registration tool on the Windows task bar. * 5 Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options. * 6 Select "Connection Status," then "Connection 3: None" and "Wireless Connection." Choose "Nintendo Wi-Fi USB Connector" from the options list, then "Next" to continue. * 7 Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect." * 8 Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
5
6
7
5
6
5
6
7
8
You will need to first download the Samsung PC Studio and install on your phone.
Once you have that installed.
Select the "Settings" option on your Samsung phone and then choose the "PC Connections" option. Select the "Samsung PC Studio" option. You can also choose the "Mass Storage" option. Connect your phone to your computer using a PC data cable. Open the "Samsung PC Studio" software on your computer. You can access the program either by double-clicking the icon on the desktop (if you have one) or by clicking the "Start" menu and then selecting the program listed there.
Hi. Here are the procedures on how you conect Wii to the internet
5
6
7
5
6
5
6
7
8
Click Messenger tab. Make sure the program window is open.
Then, click Connection Preferences. It will open up a window for you to work on setting up your connection.
On the Connection options, you can either choose:
1. Connect directly to the internet. (This is the recommended setting if you never had connection problems.) 2. Connect via a proxy server. (Use this option if you are behind a firewall and know your proxy server settings.
From the Internet connection option, you can choose among these three–Dial-Up, Broadband (DSL/Cable) or High-speed (T1/LAN). Once you’re able to select all your options, click Apply then click OK.
You may try switching connection from Connect directly to the internet
to Connect via a Proxy Server and choosing HTTP Proxy then click Apply.
This should work for you.
There are three options available to connect Nintendo wii to the :-
(1) Turn on your Nintendo Wii by plugging it into a power source and pressing the power button.
(2) Press the "A" button on your Wii controller to continue from the warning screen.
(3) Select "Wii" button in the left hand corner of the main menu, by using your Wii remote to move the hand shaped cursor over the "Wii" button and pressing the "A" button on the controller to select the Wii options.
(4) Click the "Wii Settings" box on the right.
(5) Select the left arrow to scroll over to more options. Then select "Internet" from the list and "Connection Settings."
(6) Choose an open connection by selecting the "Connection 3: None" option, then the "Wireless Connection" option, and the "Search for an Access Point Option."
(7) Choose the access point you want to use from the list that will be displayed. Save the settings by clicking "OK." Then click "OK" to start a connection test. When the test is complete you are connected.
(1) Insert the Wii LAN Adapter into the USB port on the back of the console.
(2) Connect an Ethernet cable from your modem or router to the adapter.
(3) Turn on the Wii console.
(4) Click the "Wii" options button in the lower left hand corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
(5) Select "Connection Status," then "Connection 3: None" and "Wired Connection."
(6) Click "OK" to initiate the connection test. When the test is done you should be connected.
(1) Insert the CD that came with the Nintendo Wi-Fi USB Connector into a PC running Windows XP that is connected to high speed internet. When the setup window appears click "OK" to start the installation.
(2) Choose your language and click "OK".
(3) Insert the connector into a USB port on the PC when prompted. Hook the connector directly to the PC as ports on the monitor and keyboard will not work.
(4) Click on the registration tool on the Windows task bar.
(5) Turn on the Wii console. Click the "Wii" options button in the lower-left corner. Select the "Wii Settings" option by clicking on the left square. Scroll to list more options by clicking on the blue arrow to the left of the screen. Choose "Internet" from the list of options.
(6)
(7) Return to your PC and you will find your Wii listed in the Nintendo Wi-Fi USB Connector Registration Tool window. Click on your Wii's name and select "Grant Permission to Connect."
(8) Return to your Wii and click "Next" for the setup completion window, and then click "OK" to run the connection test.
Thanks for using Fixya.
Good Luck and have a nice day.
