I am having issues with a blue line down the middle of my screen the others see. I switched computers and downloaded the drivers from Creative but is an older unit and is not supported by them anymore. Any ideas what I have to do to remove this line? I am running windows 7 on both machines.
Lighting
Lighting is a common cause of strange webcam colors. When your webcam does not have enough light, it compensates by adjusting settings internally. The adjustments can result in color shifts that are not true to life. Bright, diffuse lighting reduces the workload on your webcam and allows it to display colors as they are. The light source should be behind the computer and pointed at your face to reduce shadowing and provide an even light. Avoid light sources behind you, as they can cause extreme contrast between your face and the light. b> Webcam Settings b> Most webcams come equipped with customization settings that allow you to adjust the display. Changing the settings while watching a preview webcam image can help you fix odd colors on the display. The location of the video settings varies, but is often located in the Preferences, Settings, Configure or Video menus. Adjust the tint, contrast and brightness settings until the image shifts to a normal color scheme. Webcam Drivers b> Webcam drivers allow the camera to function properly. When your drivers are corrupt or out of date, they can affect even the most basic display abilities. Webcam manufacturers publish the most recent driver downloads on their websites, usually on the individual product page, along with instructions for installation. To allow your computer to communicate with the webcam and use the drivers, run a software update to install any recent versions. b> Special Effects b> Some webcams come with built-in special effects that allow you to customize the appearance of the video stream. If an effect was enabled during the last session, it may stay on when the camera is turned on again. Turning the effects off will usually resolve the problem. The location of video effect settings varies by webcam model and manufacturer. Logitech Video Effects are located using the mask button in the QuickCam menu.
Brian thanks for the response, my problem is a single line down the middle of the screen. It looks like it is trying to divide the screen in half but it is just one picture of me with a verticle line.
it might be a generic problem with the webcam read others with same fault only its a green stripe down middle of screen
SOURCE: unable to find drivers for Creative Live!Cam Vista IM model VFO260
You can download here from Creative.
Please don't hesitate to contact me for further assistance.
