Question about Bosch CST Berger MagnaTrak 200 Series Magnetic Locator - No. 19-200SC
The on/off switch does not turn the unit on. Tried new batteries.
Likely the on/off button is no longer at the right position to make contact with the tab. Take it apart, and you may need to glue a little piece of plastic to the button.
Posted on Nov 26, 2014
Dec 10, 2014 | Berger Instruments CST/berger LM800 Rotary...
according to http://www.engineersupply.com The CST/berger DTEP diagonal eyepiece works with the following instruments:
Apr 17, 2013 | Retail Supplies
Jan 12, 2013 | Berger Instruments Magna-Trak 102 Metal...
Remove the bolts or screws
securing the console to the upright assembly. Lift the console and
confirm that the cable connections are secure. Remove the cover from the
console's battery bay and install a fresh set of batteries. Replace the
battery cover.
Step 2
Detach the ends of the pedals
from the crank axles. Remove the left and right disc shields and side
shields. Inspect the interior of the base unit and locate the flywheel.
Step 3
Inspect the flywheel as it
turns. Locate the magnet installed on the flywheel. Turn the flywheel
until the magnet passes in front of the nearby reed switch. Loosen the
screw securing the switch in place. Rotate the switch to reduce the gap
between it and the magnet. Tighten the screw.
God bless you
Jul 31, 2012 | Precor Efx 5.17
Mar 07, 2012 | Exercise & Fitness
Nov 24, 2011 | Cst /Berger 57 LM30 Manual Leveling Dual...
Apr 05, 2011 | Acer Aspire One D250 (99802378332) Netbook
Jan 06, 2011 | CST/Lasermark Self-Leveling Rotary Laser...
May 28, 2010 | Robotoolz SelfLeveling Laser Level with...
Dec 21, 2009 | RTO CST/Berger 55 - SLVP32N 32X SAL...
260 people viewed this question
