Question about Konica Minolta bizhub Office Equipment & Supplies
KONICA BIZHUB C250 DOCUMENT FEEDER PRINTING ON ANGLE
KONICA C250 DOCUMENT FEEDER PRINTING ON ANGLE
Posted by GLEN BATCHO on
Adorjani Laszlo
  • Konica Minolta Master
  • 1,316 Answers
Clean the feeder paper feed,separator roller with cloth and alcohol.
Posted on Feb 01, 2013
5 Related Answers
Anonymous
  • 4 Answers
SOURCE: konica minolta bizhub c250- error code c-0212
Something is going wrong with your LCT!
I am looking into it...
Posted on Sep 11, 2008
Anonymous
SOURCE: Transfer unit Bizhub C250
reset life of actual transfer
Posted on Feb 14, 2009
Giamma Giamma
  • 12 Answers
SOURCE: how do you reset the life of the transfer unit on the Bizhub C250
Yes,
Remove Trasfert belt unit.
On the left handled remove one screw ( spring fixer) and remove right srew (over the belt / bar whit finger fixee).
Remove, on the left spring stoppage and metal handled.
Remove black little srew and take to hand fuse contact.
Change fuse (behind) with new identical fuse and reassembly.
It may be reset trasfert belt counter.
Sorry for my not good english.
Bye.
Posted on Mar 20, 2009
Anonymous
  • 67 Answers
SOURCE: Konica Minolta BizHub C451 printing red lines down documents
your imaging unit is damaged. call minolta guys to have a look it at and change it if neccessary
Posted on Mar 30, 2009
taminol
taminol
  • 62 Answers
SOURCE: Printing labels on bizhub C450
Hi nwillett,
Yes and no, sorry if that doesn't make much sense.
For years Minolta recommended Avery labels, but these days they recomment labels manufactured by Howard Smith Papers, their website is http://www.hspg.com/
The thing with labels is always to use the one your copier service company suggests. Otherwise they'll invalidate you contract and you'll be liable for callouts and repairs caused by using Avery labels.
However, Avery labels are good and I have experienced very few problems with them I pressume you using the lables in the correct orientation and also using the manual bypass to feed them.
Regards
Taminol
Posted on May 26, 2009
I cant print from my computer to konica minolta bizhub c250
are you the only person connected to the machine can others? try different file pdf, web page, document email
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 30, 2014 | Konica Minolta bizhub C250 All-In-One...
Error code c-5357 on a bizhub c250
Left rear looking at the copier from the front. installed at a angle. one below is installed horiz.
Jun 11, 2014 | Konica Minolta bizhub C250 All-In-One...
What are ADF edge guides
the guides that hold the original document as they go into the document feeder
Mar 13, 2014 | Konica Minolta bizhub C250 All-In-One...
Lines on documents
when using the document feeder??? if so then place a document on the big glass and make a copy if the line goes away clean the small slit glass to the left of the big glass that glass is what the doc feeder uses
Feb 11, 2014 | Konica Minolta bizhub C250 All-In-One...
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Colour printing
Hi Alan,
Please ensure that the printer driver is set correctly.
Go to your Printer & Faxes menu, right click the C250, click printing preferences, click the Quality tab and make sure Colour is selected. Apply the changes and bingo!
The above assumes you are using Windows and a PCL driver.
Hope it helps
Regards
Taminol
Mar 05, 2010 | Konica Minolta bizhub C250 All-In-One...
How do I print a two page, single sided, document onto a one page, double sided, document?
go printer driver properties device setting and enable duplexer.
secondly,when u sent print to printer befor sending printing go on properties page and select "duplex"
Oct 30, 2009 | Konica Minolta bizhub C250 All-In-One...
Duplex Printing
do you have duplex installed ? if you trying to copy duplex originals, you need duplex feeder.. in main displey the left tab is dupleks printing, if you have there options 1 -1; 2-1; 1-2; 2-2 then you have a duplex installed and you can copy/print duplex. also in driver menu there is a option duplex, wath you have to choose if you printing.
Apr 25, 2008 | Konica Minolta bizhub C250 All-In-One...
Printing Docs
This model does NOT support edge to edge printing.
You can have the document reduced to fit the sheet size in Excel.
Feb 19, 2008 | Konica Minolta bizhub C250 All-In-One...
107 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
