Question about Texas Instruments TI-82 Calculator
ERR: STAT PLOT
When I press GRAPH or TRACE I get a message saying: ERR: STAT PLOT 1:Quit What is this and how do I solve it?
    Sergeant:
  • Texas Instru... Expert
  • 267 Answers
ERR: STAT PLOT meaning tha you are trying to display a graph when there is a StatPlot On that uses an undefined list
Posted on Feb 03, 2013
5 Suggested Answers
Anonymous
  • 32 Answers
SOURCE: my TI-83 doesn't plot
The problem seems to be that the list is archived. To fix this go to memory menu (2nd and mem) then find L1 or whatever list you want and hit enter next to it. This will get rid of the big asterick and then you can graph it or you should be able to.
Posted on Dec 04, 2008
k24674
  • 8081 Answers
SOURCE: how to remove "err: invalid dim".
The solution for the problem is simple. When you use the calculator to create graphs, it is configured to accommodate the specificities of the problem. However that configuration remains set after you terminate the problem. So when you try to use the calculator to do other problems it uses the stored configuration parameters, which may be incompatible with the new problem.
In particular, list of paired-variables must have the same dimensions: There must be the same number of elements in each list.
To make a long story short, you should make it a habit to reset the Ram everytime you want to do a new problem. If for reasons of you own you do not want to reset the Ram, you can prevent this type of errors from occurring. This is how you do it.
  1. Press [2nd][Y=] (STATPLOT)
  2. Choose option [4:PlotsOff][ENTER]. Screen displays Done
  3. Press [2nd][0] (CATALOG)
  4. Press [PGRM] (C) to jump to first command that starts with c.
  5. Use arrow to scroll down to ClrAllLists, select it [ENTER]
  6. Calculator displays Done
  7. Start the new problem
To reset the Ram press [2nd][+] (MEM) [7:Reset][1:All Ram][2:Reset]. Press [CLEAR] to erase the Ram Cleared message.
Hope it answers your questions.
Thank You for usibg FixYa.
Posted on Nov 24, 2009
  • 102366 Answers
SOURCE: ERR: WINDOW RANGE 1: QUIT
There's something wrong with your window limits, for example Xmax < Xmin or Ymax < Ymin. Press WINDOW to bring up the window editor and examine the values, making sure there are no inconsistencies.
If you don't see anything wrong, post a comment here listing all of the entries in the window editor.
Posted on Feb 19, 2010
spacerook
  • 130 Answers
SOURCE: On my TI-83 Plus calculator,
First lets make sure you have a manual. go to: http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000010670.pdf Go to chapter 3 and it explains the details in graphing
Posted on Aug 11, 2010
k24674
  • 8081 Answers
SOURCE: whenever i try the graph
You have to turn all statistical plots OFF before you draw function graphs. Press [2nd][Y=] to open the statistical plot configuration screen. Press [4:PlotsOFF] and then [ENTER]. When calculator answers DONE you are ready to draw function plots.
Posted on Sep 10, 2010
When I try to graph it says-ERR:INVALID DIM 1:QUIT
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
TI-83+ calculator works fine for basic arithmetic functions but when I try to do basic graphing I get an error message that says ERR:INVALID DIM 1:QUIT. Is this repairable?
If this doesn't do it, please reply to this post and give an example of something you're trying to graph.
Oct 23, 2012 | Office Equipment & Supplies
Why do I get an ERR: Invalid Dim 1:Quit Whenever I hit the graph key?
If this doesn't do it, could you post the exact function you're trying to graph?
Nov 16, 2010 | Texas Instruments TI-83 Plus Calculator
When trying to graph a function it would say: ERR:DIM MISMATCH 1:QUIT
You're probably trying to graph a function that does not involve stat plot features while the calculator is expecting them. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
Nov 03, 2010 | Texas Instruments TI-83 Plus Silver...
When I graph, it shows "ERR: INVALID DIM 1:QUIT"
Oct 28, 2010 | Texas Instruments TI-84 Plus Silver...
My calculator will not graph the equations i put in under the y= button. it says "ERR:INVALID DIM 1:QUIT"
Oct 25, 2010 | Texas Instruments TI-84 Plus Calculator
When i press the graph button a screen that says: ERR: INVALID DIM 1:Quit
Oct 16, 2010 | Texas Instruments TI-84 Plus Calculator
Whenever I use the graph button, it states ERR:INALID DIM 1: Quit How can I fix this so that I am able to graph again?
Aug 22, 2010 | Texas Instruments TI-83 Plus Calculator
Graph
Sep 09, 2009 | Texas Instruments TI-84 Plus Calculator
My graphing calculator won't graph anything
Go to your stat plot screen, and select option 4 (PlotsOff), Press Enter, and try to plot a normal graph again
Jul 07, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-82 Calculator Logo
746 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Paul Bade
Edward Easley
Edward Easley
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
