Question about Hotpoint WMA58 Front Load Washer
Hotpoint aquaius does not spin
My machine doesnt spin and is loaded with water
Posted by Pam Kanwal on
  • Hotpoint Master
  • 17,130 Answers
Possible there is no power switched from the controller unit , You need to use a meter to check the output to the motor or else the timer panel is faulty. Also If there is power and the motor does not spin then it can be fault in the motor or the capacitor or FRICTION on the drive.
Posted on Feb 01, 2013
5 Related Answers
Anonymous
SOURCE: Hotpoint WMA50p won't spin
Had same problem today with our machine. Brushes looked OK (although one appeared a little shorter than the other).
After removing and re-fitting the brushes, motor worked fine - suggesting that it was the brushes afterall.
Now looking for replacement brushes
Posted on Mar 27, 2008
Anonymous
SOURCE: Hotpoint Aquarius WF000 - water problems.
have u tryed to clean the fillter at the back of he machine
Posted on Aug 06, 2008
Anonymous
  • 5 Answers
SOURCE: not spinning out water of Hotpoint WF 560 washing machine
pump problems
Posted on Jan 17, 2009
jgwhomeequip
Jeremy Reddick
  • 1902 Answers
SOURCE: Hotpoint WMA11
If the motor is not getting power when it is called for spin. Then check the computer and the timer. Also check the balance sensor
Posted on Feb 14, 2009
Anonymous
  • 77 Answers
SOURCE: hotpoint wt960 machine does not drain the water
Your drain pump is out. Usually attached to your motor and operates when the drain cycle is engaged. It's usally a 20 dollar piece. good luck.
Posted on Apr 17, 2009
Hotpoint wma30. Drum not draining water. Have
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Hotpoint WMA30 Front Load Washer
My Hotpoint Ultima keeps displaying an F10 fault and doesnt spin correctly. However, if I then switch it to a rinse and spin cycle it seems to spin OK.
F10 meanswater level pressure switch not sensing correctly, there could be a blockage in the switch hose or chamber, or the switch could be faulty.
Jan 17, 2010 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint wma76 stops and displays ON
Could be rinse water valve ..Faulty Solonoid coil
Nov 10, 2009 | Hotpoint WMA76 Front Load Washer
When my washing machine is filling with water at
Replace seals this will usually resolve this issue.
Aug 28, 2009 | Washing Machines
Wash machine stays on wash cycle and doesnt go to rinse or spin
If the water is not getting hot, this will probably stop the programme advancing .Check heater.
Plz rate solution to prob.
Dec 10, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WMA 32
please check the outlet hose of the detergent drawer. it could be clogged with soap.
Feb 13, 2008 | Hotpoint WMA32 Front Load Washer
Hotpoint WMA58 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
gbob59
Lawrence Oravetz
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
