Code malfunctios c1441 minolta di 450
The copiers CPU is equipped with a self diagnostics function that on detecting a malfunction,gives the corresponding malfunction code on the touch panel.Resetting a malfunction:
- Press the trouble reset switch on the technical representative setting switches board to reset fusing and exposure lamp related malfunctions.(code: C400,410,420-expo;C500,510,520-fusing unit)
- For any other malfunctions,open and close the front door or turn OFF and ON the power switch.
C1441 CCD failure(clamp adjustment failure).
Reset the malfunction,check that the original glass is properly installed.Check for extraneous light and check to see if CCD Assy and mirrors are installed at the correct position.If the same malfunction is detected again,change image processing board.
