Brother Dcp-7055 Laser Print Copy Scan 2400 X 600 Dpi Scan 20 P Logo
A
Anonymous Posted on Feb 01, 2013
Brother DCP 7055 Print unable EF
Print unable EF
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Jun 10, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
5983
Points
14
1 Related Answer
Anonymous
  • 110 Answers
  • Posted on Dec 18, 2012
SOURCE: i have brother DCP 7055 it shows print unable 71 error pls suggest
ERROR 71 &72 ARE PRINT CARTRIDGES CHANGE THEM OR INSTALL THEM CORRECTLY
I am tired and fed up from the problems appeared on the screen of Dcp 7055 that Print Unable EF
https://www.manualslib.com/manual/794794/Brother-Dcp-7055.html?page=106
Brother DCP 7055 Service Manual Error Code Ee ef
Quoting from the free manual Page 2-69:
? Error code EF
Print Unable EF
Turn the power off and then back on again.
The supplied power is unstable.
Step
The irregular power supply is
detected
Main PCB failure
Note:
• The irregular power supply detection error (Machine Error EF) occurs when there is a
large fluctuation in the power supply voltage supplied to the machine.
In this case, if the same power supply is used, the same error might occur again even if
the low voltage power supply PCB ASSY is replaced.
2answers
Brother dcp 7055 EF problem
Please provide detailed information on what the problem is; just saying model and problem give us nothing to work with.
How solution Unebal to EF in Brother DCP 7055 matchine ?
Error code EF - Irregular power supply is detected
Print Unable EF
2helpful
Printer show Print unable EF
Re-install your printer's driver in your PC or Laptop.. then try to print the Demo Page..
#NZ
Dcp 7055 machine error ef
Check the ventilation fan (not working)
Machine error ef
Solution to print unable error et
86helpful
5answers
I have brother DCP 7055 it shows print unable 71 error pls suggest
I have brother DCP 7055 it shows print unable 72 & some time it show 71 error pls suggest
162helpful
7answers
MY BROTHER PRINTER DCP-7055 EORRER REPLACE TONER
This came from the Brother HelpDesk, yes they rang me and it worked.
Cover open Press Clear "Replace Drum?" (ignore this and quickly...) Press Start (blank screen, quickly...) Press Up arrows then switch to down arrow to 00 Press OK
80helpful
4answers
Brother dcp 7055 error-EF
brother dcp 7055 error-EF laser
Norman Weimar
Norman Weimar
k24674
