Question about Zapco 1100M Car Audio Amplifier
How many ohms is model 1100.m - Zapco 1100M Car Audio Amplifier
Model 970-6874 oven overheated, couldn't shut it off. Had to turn breaker off. It read f10 ERR. Oven was so hot smoke detector was going
This oven was manufactured by Electrolux. However, you should double-check the model number. There should be two more digits in the number.
The F10 error indicates a run-away oven temperature. You need to unplug the oven or turn off the circuit breaker for at least 5 minutes to reset the error. Sometimes, the EOC (electronic oven control or main board) needs to be replaced. The oven temperature probe sensor may also be bad. This sensor can often be accessed through the oven; look for mounting screws on the inside back wall of the oven. Otherwise, you need to take off the back panel. The resistance across the sensor should read 1100 ohms (the wires to the sensor are usually violet). If you see a reading above 2000 ohms, replace the sensor. If the reading is 1100 ohms, then the control board is the part to replace. However, if the oven became too hot, the entire range need to be replaced. If your oven is under warranty, contact Sears for service.
I hope this helps. Please add a comment with the complete model number if you'd like help finding the parts for your range.
May 17, 2016 | Kenmore Kitchen Ranges
Are sony xplod 1100 watt 10'' subs 2 ohm stable
No keep on trying end blow everry thing up, Buy some real subs.
Nov 29, 2012 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Troubleshoot oven temp model#RF388LXKT0
The oven tempature is controlled by the oven sensor and if the temp. is off the sensor is very likely the problem. To test the sensor it should be unplugged from the wire it plugs into and use a multimeter set to measure ohms of resistiance and check the sensor at ROOM TEMPATURE to be between 1060-1100 ohms if its substantially higher or lower that 1060-1100 when checked at room temp. the sensor is bad.
The sensor is located in the oven chamber and it can be removed to test it by unscrewing it from the back wall of the oven cooking chamber,here is what it looks like oldtech2332_140.jpg
GENE
Oct 13, 2011 | Whirlpool Kitchen Ranges
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
My oven displayed F5 then F3 code I believe after a nearby lightning strike, When installing new sensor with supplied wire nuts I found black marks on oven side connector. Immediate F4 error code when...
When checking the sensor it shouls be checked at room temp (even if power off) at it should be between 1060-1100 ohms at room tempature. 16 ohms the new sensor is shorted the F2/F3/F4 all relate a faided sensor and the F5 error code says the clock (electronic oven control) is defective.
Test the sensor again at room temp...if only 16ohms its no good and will throw the F4 code everytime again a good sensor measured at room temp should be between 1060-1100 ohms
GENE
Sep 06, 2011 | GE JTP15 Electric Single Oven
F1 error code on the ERC. No replacement ERC from Sears (Kenmore) or GE (manufacturer). The oven temp sensor is within specs at 1100 ohms @ RT.
The F1 error code refers to one of the buttons on the touch pad being the problem and not spefically the erc unless on your model the touch pad is built in to the erc.On older model the touch pad was a different part on newer models its only part of the erc
Yes indeed 1100 ohms is the exact spec.for the sensor at room temp. however if the sensor were bad the error code would F3 if had a open circuit(infinate ohms) and F4 if it were shorted(zero ohms)
Jul 29, 2011 | Ovens
After removing the heat sensor i closed the door. Now I cannot open it please help. F3 code.
The error code F3 indicates an oven sensor problem. You will need to remove the back of the range and locate the temperature probe (usually in the upper right hand corner. First disconnect power to the range. Ohm the probe, it should ohm approximately 1100 ohms at room temperature. If not, the probe is bad. If the probe ohms near 1100, you will then need to make the same measurement at the EOC (Electronic Oven Control) with the probe connected to these wires. If you get 1100 (approximately) the control is bad. If the probe ohms correctly and you have a different reading down the wires from the control the wires are bad.
Jan 22, 2011 | Frigidaire FEF336BC Electric Kitchen Range
How do i know if its my temperature sensor, or heating elemnet that isn't working?
HI. You can administer a simple continuity test on the element to confirm failure. A burned out element will show no continuity, when measured. As for the sensor, A simple resistance test can confirm functionality in this case.
The most common oven sensor should be approximately, 1100 ohms when at room temperature. The others may be close to as follows:
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor resistance is lower than 1100 ohms, This will confirm that the sensor is faulty. If it is higher than 1949 ohms, this will confirm failure, as well. replace it in this case.
Dec 22, 2009 | Whirlpool Kitchen Ranges
F4 shows on display.What does this mean? This is a Kenmore..can't find model #
HI, You will need to check the oven sensor wires that link the actual sensor to the main control board. Make sure that the contacts are connected properly, and not loose, or corroded. If all the wiring checks out, test the sensor for the correct resistance readings.(you will need a multimeter for this test)
100°F - 1143 ohms
200°F - 1350 ohms
300°F - 1553 ohms
350°F - 1654 ohms
400°F - 1753 ohms
500°F - 1949 ohms
If the sensor test is adequate, and the wiring is Ok at the control, this will lead to a failed control board. replace the control in this case.
F-4(Failed sensor circuit)
Nov 20, 2009 | Kenmore 92022 / 92024 / 92025 / 92029...
Oven temp does not remain constant. changes + /- 50 degrees.
Sounds like either an intermittent temperature sensor or its wiring, OR a problem with the electronic control.
We repair a lot of controllers with this sort of symptom.
Best Regards,
Bruce
www.fixyourboard.com
Oct 14, 2009 | GE 24" Built-In Single Gas Wall Oven
Zapco 1100M Car Audio Amplifier Logo
Top Zapco Car Audio & Video Experts
Marvin
Marvin
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
