I just bought the car and did not think the cd player was working but when i put the disc in it came on and then i turned the radio on i could not get the cd player to play and the disc is still inside.
Kirk, I am not aware of any fuse to remove to make player work. Try cleaning the lazer/head. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." CD player doesn read disc 2007 Sonata Ltd CD player won read discs How to Fix Car CD Player
so is this a stock RAD/cd?
stock JBL 6 disk player in dash>? or? what? name and model #
mp3 and wma format. but not DVD
or
JBL premium 4-disc in-dash CD changer
io the single disc player, 3 kinds sold. new.
and now comes the big question.
TELLS where you got the disk, or name it, or tell how it was made if home made. we dont know that.
is said CD a CDDA? or not. (always try CDDA first)
is CD a real music disc. from a real store, CDDA, is that.
or CDR, or DVDr, or CDRW, or other record-able media
is music MP3? files.
see, the old units dont play modern media.
try 2 real discs, not scratched.
do they play?
one other way, is to name the radio, brand, like JBL then get the
p/n off it. (hard) then look up the product data sheet on it,
bingo, what it can and can not do is there.
but this does it all, mostly
does what yours will not do.
http://www.flyaudio.net/product_id.asp?id=113
I had the error code no. 1 in my 2007 Toyota Camry Hybrid. It has the CD radio unit with JBL system. It will not eject the CD, or play it. I removed the entire radio/CD unit and replaced it with a used excellent unit bought off of ebay for $100, and the replacement works fine. However the replacement is also 7 years old. Therefore I would not be surprised if it failed again. Prior to the error 1 I had intermittent error 3 codes, which had the same effect: no playing of the CD, unable to eject, and unable to insert other CDs. Sometimes the error codes would go away, and the function would be normal. But once it started, I think it was on a downhill path. A new replacement is nearly $2000. Used are about $100 to $200 or more depending on the seller and condition of the unit. Youtube has videos on how to replace the unit which only requires simple tools: it is not difficult but takes about 45 minutes to an hour. If you do it you have to put the car in gear to move the gear shift gate, which requires the car to be on, so you should have the parking brake on for safety. One alternative is to send your unit to a repair company but that might cost more than simply replacing the unit. Good luck!
you can replace your CD player with the same type, or you can buy the chinese product working well that I bought for my car priced 120 USD. that is a touch screened, with MP3, USD aux input ...etc.
I had this happen in my old dodge stratus. My trick to remove cd's was when you stopped or parked the car turn vehicle off and hit the eject button and it will usually eject the disc. remove all discs and then install them again when car is parked and not moving as vibration and bumps while driving can sometimes miss align the disc in the player. Sometimes when the stereo didn't work at all I disconnected the battery and it would reset and work. If this doesn't work it may be broken. Good Luck.
try another cd wont play if too scratched or dirty. handle disc by edge, dont touch the surface of disc no matter how lightly you hold it, you will leave contaminants that cloud the surface. if none ever work try them in a house cd player still no joy, then discs aare no good, if they work in home player then car cd died, time for new one. heck who uses cd any more? its a hassle to change them (only 16 songs!), hassle to replace lost daamaged or stolen(borrowed by friends), skip or scratches, get a radio with usb reader/player or SD card reader, can be had for under $60 , an 8gb SD card for $25 (4,000 songs<do you even KNOW the names of that many songs?) PLus, without a cd slot the thieves should leave your radio alone, thinking its just a normal am/fm radio. goto www.dealextreme.com for great deals and FREE SHIPPING.
If this is a consistent symptom that occurs with all your cds....I would have to say the laser in the cd player is no longer working. You may try cleaning it, there are cd cleaners that are 15$ that u can try.but i think you'll find its out . sorry
Are you using burned discs. If so try burning them at the slowest speed available on your computer, usually about 8x. If your using standard store bought CD's then you might have a lens issue. Try purchasing one of those lense cleaner discs, they have a tiny brush on them that cleans the lens while it spins, they work pretty good.
I have had similar problems in the past - on one computer discs burned using nero were unreliable but using Windows Media Player they were fine and on other computers the Windows programme was useless and produced unreliable inconsistent results.
I suggest you experiment with different burning software and maybe suspect the drive you are using might be past it's best.
I have several cd players in my vehicles and around my home. Only a couple of them will play all the discs and most of them are very choosy and will only read premium price shop bought discs and it is a waste of time trying to play a discount store or freebie disc, or many of my computer burned discs.
I don't know what the differences are - maybe it is the software or the power of the laser burning the disc or the sensitivity of the reading laser, but there are many differences in there somewhere. The situation is very frustrating...
lots of failures on these 6 disc players. if you push the numbered button the coresponding light should eventually turn green meaning its ok to load a disc. If your not sure if the player works I would recommend a copied disk or one you dont care about in case it eats it, mine did.
