Question about RCA F31672ET TV
How do you hook up the wii to the tv? - RCA F31672ET TV
How do you hook up your wii on the tv so you can get netflix and tv channels
You hook the wii up as normal. The wii needs to be able to connect to the internet. On bootup go to the wii shop, channels and download Netflix or Hulu Plus. (Sign up for those services seperately)
Oct 06, 2013 | Nintendo Wii Console
Specific info re hooking up Wii, no instructional manual. What is specifically needed to play the games?
To play the game you need to hook up three main things.
  • First plug in the RCA cables (red, yellow, white) to its corresponding jack on the wii and colors on the TV
  • Then plug in the sensor bar into the wii and place it either above or below the TV
  • Lastly hook up the power into the wii and the power outlet.
Power it up and play!
Jul 03, 2011 | Nintendo Wii Console
We are trying to hook up our wii console how do you get it to work. TV says invaild scan freq.
You have to hook it up to a standard Yellow/Red/White RCA jack. If it doesn't work on one, try another. Make sure you're on the proper input you hooked it up to on the T.V. If this doesn't work, try hooking it up to a different T.V. to rule out the Wii as the problem. Try hooking up a DVD player to the same RCA jack as the Wii was on the Hitachi. After all of these troubleshooting methods, you should be able to get your Wii properly hooked up.
Jun 24, 2011 | Hitachi UltraVision UT47V702 47 in. LCD TV
How to connect a wii to my tv
Please take your AV Cord and hook it up to your wii and your tv. There are 3 colors. Red/White/Yellow
Once hooked up, take your remote and switch the Video Input on your tv. (look for the input button)
Make sure the Wii is powered on and you should see it pop up on the screen.
Dec 31, 2009 | Nintendo Wii Console
TV went to black and white when hooking up the wii
You probably don't have something hooked up right or connected all the way. If you are using component video cables, make sure that all of the different plugs are plugged into the matching socket on your TV. Also, make sure you have your TV on the right channel (3 or 4) if that's how you have it setup.
Otherwise, you will want to look at the input settings on your TV and make sure you are receiving the correct input, and if you have your Wii plugged into a VCR instead of directly to your TV, try hooking it up directly to see if it works.
If that doesn't work, try using a different TV - especially if it's a TV you know works in color with a Wii. If it is still in black and white, you might need to take it back to the store and exchange it for a new one.
Nov 23, 2009 | Nintendo Wii Console
Hooking WII to TV
check your using the correct AV channel for the connection. Try another input connector eg Scart
Jan 20, 2009 | Nintendo Wii Console
Hooking up wii
you can do it multiple ways. like putting the cords into the dvd then putting the dvd cords into the tv, or put it into the tv, or hook it up to satilitte and hooking up to the tv. your choice.
Dec 26, 2007 | Nintendo Wii Console
Televison & Video Logo
26 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
