Specifications Processor
Intel® Pentium® dual-core mobile processor T3200 (1 MB L2 cache, 2.0 GHz, 667 MHz FSB Operating System
VGA
14.1" WXGA high-brightness Acer CrystalBrite TFT LCD, 1280 x 800 pixel resolution, supporting simultaneous multi-window viewing via Acer GridVista Memory
1GB of DDR2 667 MHz memory (upgradeable to 4 GB using two soDIMM modules)
Gra Audio
Two built-in stereo speakers High-definition audio support MS-Sound compatible Built-in microphone
Storage
One 160 GB or larger hard disk drive8 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick (MS), Memory Stick PRO (MS PRO), xD-Picture Card™ (xD)
You can upgrade memory up to 4gig and hardisk up to 500g
You have the correct memory, however, did you replace memory in both available slots with same capacity/clockspeed sticks? The below is from the Spec sheet for your computer.
512MB(min)/2048MB (max), 2 memory slots using 256MB, 512MB, 1024MB or 2048MB PC4200 DDR2 533MHz SDRAM,
dualchannel support requires two memory modules of same capacity and clockspeed
You can confirm this in the BIOS and i'm sure it will show 4GIG. Your Operating system maybe a 32 BIT OS, hence it will only show about 3... GIG. It's a limitation for a 32 BIT OS.
I have the same issue with my laptop. I have not been able to get the laptop to accept 2gb of memory yet, but I did find something that works. If you put your 512mb memory that works in the laptop and then add a 1gb stick in the second slot it works. Or at least it did for me. It's better than nothing. I am still trying to figure out how to get it up to the 2gb max. Will add a solution if I figure it out.
yeah,reseating the cmos battery will reset you bios settings to factory default,so whatever memory that is attached to your computer should be detected..
Your Laptop is using DDR2 Memory, just find your nearest retailer that sells memory and go buy you a chip, ur laptop ships with 1024mb of ram as standard, if you want to get a decent boost pretty cheap then i would just buy another 1gig chip and put it in beside the one already there.
Not sure what your system maxes out at but the average is 4gig of ram so you could try a couple of 2 gig chips if you feel you need that much ram
if you are using the handy cam just look at the specs on the manual to determine what memory card is compatible. based on your info it is unlikely that the camera even supports 4gig of memory. You should try the smaller sony memory stick up to 2gb only and it should work. good luck
