Question about Sony BM-850T Desktop Cassette Transcriber / Recorder
Sony microcassette won't play beeps when you push play
1 Related Answer
3vil3lvis
  • 43 Answers
SOURCE: how do I erase tape on sony microcassett
Hold down the 'Erase' button and press the 'Rewind' button. It will erase the tapes as it rewinds.
Posted on Jun 07, 2010
How do i get a sony microcassette transcriber m-2000 to play/rewind/fast forward continuously?
Probably has a bad sensor belt (small belt attached to silver and black reflective wheel).
Aug 07, 2014 | Sony M-2000 MicroCassette Transcriber...
Microcassette won't play but does rewind and fast forward
I have the 3 of these units at my office with the exact same problem. Turns out, with a little tinkering there is a simple fix.
Open up the unit (by unscrewing the two screws underneath) and look for a brass disk with a black rubber band around it that connects to a small tip. The rubber band should be either stretched, broken, or even melted. This is the problem. Over time the rubber band deteriorates which causes the unit to not play a tape (rewind and fast forward operate differently).
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and will be difficult to remove.
Hope this helps.
Apr 14, 2013 | Sony BM-815 / BM815 Micro Cassette...
WON'T PLAY BUT WILL REWIND AND FAST FORWARD
Replace the deteriorated rubber band with a new one similar in thickness and size. That should work like a charm. Be careful if the original rubber band has melted. It is tar-like and it will be difficult to remove.
Hope this helps.
Sony m-2020 tape will not move in record or play mode
here's the manual of this recorder. You can take a look at it to see if there are any explanations regarding the error:
http://ec1.images-amazon.com/media/i3d/01/A/man-migrate/MANUAL000033419.pdf
Oct 04, 2012 | Sony M2020 / M-2020 Microcassette Dictator...
My play station won´t turn on, when you push
You need to reflow your motherboard with a heat gun. You have ylod or yellow light of death. Easy fix.
Nov 21, 2010 | Sony Playstation 3 (PS3) Console
How do I erase tape on sony microcassett
Jun 07, 2010 | Sony BM-850T Desktop Cassette Transcriber...
Suddenly my Sony M-2000 Microcassette Transcriber will not PLAY. The tape will Rewind and Fast Forward fine, but when you push PLAY, it just beeps and won't move. Any ideas?
Just talked to Exec. Communication Systems. He said that the play motor is not turning (the rewind and fast forward uses a separate motor) and the problem is either the belt or the motor. They can repair them at $82.00 plus parts and shipping.
May 18, 2009 | Sony M-2020 Desktop Cassette Transcriber /...
20 year old Dictaphone Voice Processor Microcassette not working
Not sure if you're still having problems with this portable, but the first thing I would check is to make sure that you've put the batteries UNDER the battery clip in the battery compartment. Does the machine just make a 'beeping' noise when it tries to play, rew, or FF?
Apr 04, 2009 | Dictaphone 1243 Handheld Cassette Voice...
Sony BM-850T Desktop Cassette Transcriber / Recorder Logo
120 people viewed this question
Top Sony Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
