Heating & Cooling Logo
Anonymous Posted on Feb 01, 2013
My Comfort Zone heater has 3 symbols that change when you push the Mode button- what do they mean? theres a round thingy at top, a sun in the middle and a tree on botto m.
Its a CZ20110 model
  • Anonymous Feb 02, 2013
    In the little window on the front where it tells the temp and a pic of fan blade going round and round-to the left of that is the three symbols the round thing the sun and the tree
  • Thomas Woodburn
    Thomas Woodburn Jan 27, 2019
    top is high heat middle low sorry
Thomas Woodburn
Level 3:
  • Master 2,638 Answers
  • Posted on Jan 27, 2019
Thomas Woodburn
Master
Level 3:
Answers
2638
Questions
Helped
1250650
Points
7008
The top is low heating middle is high heat bottom is energy saving mode.
Lisa Lowery
Level 1:
New Friend:
  • Contributor 1 Answer
Lisa Lowery
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2884
Points
I was wondering what the three mode settings are
5 Related Answers
Anonymous
  • Posted on Oct 14, 2008
SOURCE: comfort zone infrared heater
Hello all , just push and hold the two buttons on the right for 3 seconds and it will reset. Joe
Anonymous
  • Posted on Dec 06, 2008
SOURCE: Comfort zone infrared heater
The heater has to calabrated, this is done with a special remote control, that the people have you bought it from. It is a simple fix
reddyanantha
anantha reddy
  • 205 Answers
  • Posted on Jun 22, 2009
SOURCE: dont know what buttons mean
hai sir the button which you are confused in is used only for reseting the equipment.please find your equipment seller for a copy of users manual.
Anonymous
  • 1515 Answers
  • Posted on Dec 05, 2009
SOURCE: cz 446 comfort zone ceramic heater shuts off
Hi, the problem you are having is the thermostat control, and dimming the lights is a indication of the neutral side of the control if faulty.It is drawing enough amps to make you're home lights blink, so I would stop using it now and if you are inclined to replace this control yourself I would. If this is something you would not care to take on, I would get an estimate for repair at a appliance repair store, compared to replacing the unit with a different one.I am sorry to tell you this, but it will only get worse and what I have recommend is for you're safety.
Sincerely,
Shastalaker7
PS Please keep me informed of the situation, as I would love to be of any help you may need.
emissionwiz
Marvin
  • 85242 Answers
  • Posted on Sep 10, 2010
SOURCE: I have an AO5 error
what is A05
I have a comfort zone model CZ2011C. We have no heat all weekend til Monday .will these heaters be safe to run? Help!
The main issue with space heaters is either setting them too close to something flammable or them getting pushed over, They are supposed to have a tip switch in them though. The issue about drawing too much electric current could be a problem. Dont put them on the same circuit. They should not have any other concerns about running.;.
Why doesn't the fan on our comfort zone heater turn on when I turn on the power?
You need too hit the temp button increase temp then hit enter or set
THERE ARE 6 BUTTONS ON THE TOP PANEL ... TWO R USED FOR UP AND DOWN OF TEMP . REST I DONT KNOW. SO NOW THE HEATER RUNS FOR 2 TO 3 MINS AND THEN FAN GETS OFF DISPLAYING FIGURE OF 11 ON DISPLAY.
Power or on/off button to control power.
Now symbols:
1. fan leaves - Fan only
2. Rain drop- Dry mode
3. Snow flake-Cool mode
4. Sun- Heat
5. A or AU- Auto mode.
11 Error code means communication wiring is incorrect. check and rectify in your thermostat.
Thanks.
5helpful
Which symbol on remote is cooling? I dont have a manual but is on the wall, symbols are a fan on the bottom LH, an a sun on top LH I think? Are you able to help me with modes to select please?
Symbols:
4. Sun- Heat
L-means fan speed low
M-means fan speed of med H-means fan speed of high.
To get proper cool, mode "cool" and less 3 degree minimum than your room temp.
To get proper Heat mode "Heat" and 3 degree more than room temp. Hope, helpful
Is there a recall on the Comfort Zone CZ7007 heaters? I have two that do not work.
Have you tried resetting the unit?
Or what are the problems you are having with them?
What lights are lit, etc.?
Tell us more--
Mack B
5helpful
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
59helpful
2answers
Change temperature from Celsius to Fahrenheit on a comfort zone h
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release. - VS
59helpful
4answers
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
