Dell Latitude E6400 Laptop Computer   PC Desktop Logo
Question about Dell Latitude E6400 Laptop Computer PC Desktop
How to make it run faster
It is moveing slow how to make it run faster
max carson
  • Dell Master
  • 7,627 Answers
Many things slow down a computer over time. A little housecleaning will help. There are many Freeware programs to assist. 1, CCLEANER at : http://www.filehippo.com/download_ccleaner/ This freeware program will remove the junk from your machine, In the TOOLS section, STARTUP section, Disable ALL unnessary startup programs, in UNINSTALL section remove unnessary programs, Toolbars, etc. 2, MALWAREBYTES at : http://www.filehippo.com/download_malwarebytes_anti_malware/ In the install, UNCHECK the TRIAL PRO version, you want the freeware version. Run a FULL Scan, Delete ALL results, Reboot. Here are some basic tips for Win Vista speed up: http://www.pcworld.com/article/143538/windows_vista.html You could always do a Full System Recovery, but that a bit of a pain.
Posted on Feb 01, 2013
Anonymous
  • Dell Master
  • 32,281 Answers
If your computer has less than 1Gb RAM then install more RAM will help.
If you have a virus program installed, it is most likely is running a scan on your hard disk. It can slow down your computer especially if you have a large hard drive.
To make your computer (hard disk) lean and mean, uninstall any programs you do not use.
Also you need to maintain your hard disk by running Disk Cleanup this will remove old temp files and old compressed files etc.
This will reduce the number of files the virus scanner has to scan. Plus running Defrag. this makes your files contiguous so the system can access files off the hard drive quicker because it does not work as hard.. Disk Cleanup and Defrag should be carried out at least once a month.
If you have 512Mb of RAM installed then installing more RAM will speed up your computer. After installing your graphics card, you may need to disable the built-in graphics card in the BIOS for the new graphics card to work properly.
Computer running slow
do a massive clean out of unused programs , and data
run the defrag program
in the search box under the programs on desk top screen type in CHKDSK and run that as it fixes any faults in everything ( takes about 6 hours to do the job but it fixes files and registry faults)
If still slow remove the disc type hard drive and install a solid state hard drive --much faster , no moving parts and stores more than a disc
Why does my husqvarna running slow?
Try changing the drive belt, it's probably slipping.
Try changing the drive belt, even a slight slip on the belt will appear as a loss of power.
4answers
I have a problem with the hands on Buzz. The hands were moving fast, but all of a sudden it moved slow. How can I make the hands move fast?
To make the arms move faster, remove all the batteries and the batteries on the remote control.
Buy brand new batteries and insert them in. Turn buzz to TRY ME on his back. Stand him up and turn him OFF for 5 seconds. Then turn him to PLAY and the arm will move faster.
/uploads/images/8_4_2014_7_01_51_pm.jpg
2answers
My computer starts at the blue start up screen and it takes it about 10 minutes to load the log in screen. It wasn't doing this at first. I have done multiple system restores, but it hasn't helped....
hi Jamiekom.
Slow Running Computer Fix. Use MSCONFIG to improve computer's speed at startup. You can disable certain programs that auto-start at startup and spend less time waiting for your computer to fully boot. Simple tip to improve your computer's performance.
Why is computer so slow to startup? My Windows computer boots up slow. A slow Microsoft Windows boot up can be caused by a number of different issues. The following document contains various suggestions and tips that can help improve the overall speed of your computer's startup.
Why does it take so long to boot up my computer?3. Upgrade your hardware. A new computer is naturally going to start up faster because it has faster hardware, and a clean operating system. ... As we said above, computer startup is slow because you're moving information from a slow hard drive to faster RAM
Computer running slow at startup Check out this Quick Tip
computer slow on start up Google Search
1helpful
2answers
How do you control how fast or slow a grandfather clock runs ? Does lowering the pendelum disc make it faster or slower ? Thank you !!!
The longer the pendulum the slower it will swing, so lowering it will slow the clock down.
Feb 10, 2011 • Watches
MY LAPTOP MOVES SO SLOW I FEEL LIKE DELETING EVERYTHING ON IT AND START FROM SCRATCH AGAIN CAN YOU HELP ME ?
de frag it. go into your start menu/accesories/system tools/ disk defragmenter. it will take a few hours but it will make you computer run faster. basically it takes all the files that are spread out and compresses them to create more space and make it run faster
My pc is moveing slow can it move faster
You can make a computer move faster by removing some unecessary program that is installed on your computer to free up some memroy space and the best way to make much faster is upgrading the RAM or memory of the computer because the higher the RAM/memory the faster the computer works..
Hope that helps.......
Clive
Clive
Steve Sweetleaf
Steve Sweetleaf
