Garden Logo
duane daniels Posted on Jan 31, 2013
What is the spark plug gap on a Poulan pro 260 chain saw, 42cc?
Clifford Randolph
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 17, 2022
Clifford Randolph
Contributor
Level 1:
Answers
Questions
0
Helped
655
Points
.25 is the setting, but if your saw is hard to start after operating .30 will alleviate this problem.
5 Related Answers
Anonymous
  • 2176 Answers
  • Posted on Feb 25, 2009
SOURCE: chain sprocket
I looked at a breakdown for the 42CC not sure if the same one or not but it appears that the chain sprocket is held on by an Eclip and behind that a flat washer. If this doesn't look like yours give me the model number and I will research another breakdown
steve_lima
steve
  • 181 Answers
  • Posted on Jun 06, 2009
SOURCE: Pouulan Pro 260 chain saw - installed brand new
thake the muffle off and look inside the hole at the piston.if you see any marks on the piston,the saw will never start.you need to change the piston and cylinder assy.the cost is about $150.00 for the parts.that does not include any labor cost.most of the time it's not worth repairing.let me know if this helped or not...................................
Anonymous
  • 2220 Answers
  • Posted on Feb 19, 2010
SOURCE: 18"poulan chainsaw
Start at 1.5 CCW form lightly seated then tune for performance like this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – may not be highlighted) files that I find most helpful, I think you will too.
I think your starting procedure may be the cause of flooding. Flooded is the #1 cause of hard starts in 2-cycle engines. Read carefully the recommended start in your manual. most miss the second note. It should be similar to this (read 3, read it again):
Warm start in the manual says 1/2 choke BS. Close choke, (sets fast idle) open choke, pull rope.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close) choke, set fast idle (done when choke closed on some saws); pull starter and listen for an attempt to start. once heard (usually two pulls; no more than 4).
  4. Set compression release – optional step even if saw is equipped with a compression release.
  5. Push (open) choke pull starter until it starts (usually first pull).
Warm:
  3. Pull (close) choke, set fast idle (done when choke closed on some saws) – Do not pull with choke closed.
  4. Push (open) choke, pull starter until it starts (usually first pull).
If you still have trouble reply as you did before. I will get back to you. HTH
Lou
Testimonial: "you'all have been very helpful.to even ask a question at a repair shop around here you must first hand them your wallet! Thank kindly"
Anonymous
  • 2220 Answers
  • Posted on Mar 21, 2010
SOURCE: What is the compresion for the Poulan Pro 42cc.
Answered in CR
Anonymous
  • 345 Answers
  • Posted on Apr 28, 2010
SOURCE: carb rpl and adjustment
you have 2 screws marked H and L. With the engine running, turn the L (low) screw for best idle. Then for the H (high) screw, Hold at full throttle, turn screw, and listen for smothest and fastest revs.
Where can I find a thumbwheel adjustment foe a poulan chainsaw?
You can find just about any item needed to fix you chainsaw on www.ereplacementparts.com
I am not sure if you have the Poulan 260 pro, but I have attached the link from e replacement parts for that saw.
http://www.ereplacementparts.com/poulan-260-pro-chainsaw-parts-c-16962_17133_202439.html
Good luck in fixing your saw.
What size spark plug for poulan 42cc chain saw?
It depends on the model number for your saw.
Please re-post with you model number so that I, or others, May further help you.
2answers
1helpful
What spark plug (make, number) can I get for a Poulan 2025 chainsaw and what gap?
Replace with Champion CJ-7Y or RCJ--7Y spark
plug and tighten securely with a 3/4 inch
socket wrench. Spark plug gap should be
0.025 inches
R stands for resistor on the RCJ-7Y. Either plug will work.
PDF of Owners Manual
If you have other questions about your saw, there is an 800# at the top of PDF.
Hope this helps.
4helpful
How does the throttle cable route on a poulan pro 260 42 cc chain saw
HOW DO I INSTALL AN ACCELERATOR CABLE ON MY 260 PRO POULAN CHAIN SAW?
3helpful
Proper spark plug gap for poulan chain saws
I believe the proper spark plug gap for poulan chainsaws is .025-inch. That goes for all units.
Poulan pro 260
Clearance from coil to flywheel should be around .010
Top Garden Experts
Jay Finke
Jay Finke
john h
