I have a dryer that continues to run all day long but my clothes never get dry. What can I do to fix this or is it time for a new dryer? Also, when this first started to happen the clothes wouldn't dry unless the knob was turned to an exact spot on the dial, but now that doesn't even work.
SOURCE: Autodry cycle never stops
hi thanks for the question ther is a thermostat on the air duct at the back of the dryer it has 2 wires at ends and 2 wires in the middle smaller ones this thermostat opens to turn off heat and the small wires on this thermostat when the heats shuts off then power goes to the timer and not before if it shuts off on timed dry timer is ok i would vacuum the dryer make sure all the vent right to the outside is clean as air flow restriction can cause this problem thanks the appliance doc
SOURCE: Samsung Electric Dryer
I have had the same problem with mine, they (being the repairman) came out and have replaced the sensor and the board and it still does this, they said that there is nothing else that they can do. Don't know what I am going to do from here
SOURCE: DBXR453ET3WW Electric Dryer Won't shut off unless on timed cycle.
hi thanks for the question in the ge dryer theres 2 elements so if one is not working you only get half heat i would check the heater thanks the appliance doc
SOURCE: The dryer starts without using the start knob when
Assuming that you have GE dryer DBXR463ED0WW,
Sounds like there is a couple of problems there:
There should be a schematic diagram inside the control panel, use it to for diagnosing the problems you described.
Good luck,
Vlad
First Choice Appliance
SOURCE: Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
The dryer is clean of all lint, so is this more a thermostat problem or sensor problem?
I would like to fix this myself.
