Question about Konica Minolta Bizhub C300 All-In-One Printer
Administrator log in - Konica Minolta Bizhub C300 All-In-One Printer
Posted by HansL on
Zaheer Ahmed
    President:
  • Konica Minolta Expert
  • 347 Answers
1-Press "Utility/Counter button from control panel.
2-Press "Administrator settings" from Touch screen LCD menu,
3-Enter "Admin Password" which is 12345678.
4-After entering the above password, press "ENTER" or "END" button, (appeared on top right side of menu).
5-After pressing the end or enter button you will be in administrator mode.
Now, if you are asking about the Administrator password, then the password is "12345678" This is the default administrator password of Konica Minolta bizhub MFPs and Photocopiers.
For any other queries, feel free to ask any time.
Posted on Feb 02, 2013
Konica Minolta 164 Admin Password
Logging in as an administratorSome of the settings available in PageScope Web Connection can only bechanged by an administrator.
These settings are only displayed when you login to the administrator mode.
Logging in to administrator mode
1 Enter the administrator password in the "Admin Password" box at theleft of the screen.
2 Click the [Login] button to log in to the administrator mode.
3 To log out, click the [Logout] button.
NoteThe default password for administrator mode is "sysadm".
Be sure to change the administrator password before using administrator mode.
If no operations are performed for 10 minutes, PageScope Web Connec-tion automatically logs out.
The machine cannot be used while you are logged in to PageScope WebConnection with administrator mode.
In addition, if the machine is being operated, the administrator cannot logon
Apr 01, 2017 | Konica Minolta Office Equipment & Supplies
Administrator login
Have you tried logging in at localpc\Administrator with blank password?
Dec 26, 2013 | HP Computers & Internet
Log on as administrator
Here are two views on how to create computer administrators and administration rights
WHEN LOG IN SCREEN WILL APPER THAT TIME JUST PRESS CTRL+ALT+DEL THREE TIMES LOGIN PAGE WILL CHANGE PUT THERE
administrator and press enter if any password you put during installation of xp put that password do log in and then go to user accounts which is in control panel from there change the user rights which you want to or
right click to my computer and go to manage and then users from there also you can set rights
Here we go just press this keys ctrl+Alt+Del it will bring you a new logging dialogue box. type the user name as administrator and leave the password blank.
press enter and there you go. that means you will log into your computer as local administrator. from there go to your control panel, click on user accounts, change my account type,
from the next stage choose administrator, click change account type
hope this helps
Apr 27, 2012 | Computers & Internet
How do i login on as administrator on my computer?
Login With the Administrator Account in Windows XP Professional
Click the "Start" menu and then click "Log Off."
Click "Switch User" when the prompt screen opens.
Press "Ctrl," "Alt" and "Delete."
Click on "Administrator" when the "Log on to Windows" screen pops up. Type in the administrator password, if applicable.
Click "OK." You will now be logged in as the administrator.
Log On as An Administrator in Windows Vista
Start your computer and allow it to continue through its startup process. By default your computer will simply load directly to the primary user account (usually the administrator account), but if there are multiple users on the system it will load to the account login screen.
Use the mouse to click on the administrator account from the list of available accounts to log on. This step is only necessary if you've customized Windows Vista with more than one account or you have set the operating system to load the login screen first.
Enter the password required in the password field to log on to the administrator account.
Click the "OK" or "Log On" button once you have entered the password. This button may be labeled differently depending on the version of Windows Vista or any GUI (graphical user interface) changes you may have made.
Log on as an administrator from within the Windows Vista environment by clicking on "Start" and then "Log Off." As soon as you have logged off, you will be returned to the login screen where you can choose the administrator account from the available list.
If this answer helpful please vote me.
Good luck.
Thanks for using FixYa
Jan 17, 2011 | Compaq tc4200 Tablet PC
Got an error message 1935 while downloading software for a printer. tried sfc /scannow per kodak help tech, message said must sign on as administrator in console session to do this. how?
I think your system has many user accounts to log in. In your case I think you are logged in as other user in spite of administrator so the person who logs in as administrator has kept some securities so when you are trying to download anything it will ask administrator's permission,To avoid this type of errors always log in as administrator, or just remove securities from the administrator's account.
Thanks.
have a great day.
Oct 01, 2010 | Computers & Internet
I could not do Map Network Drive from other pc to my Dell Inspiron 1501. It looks like security setting is violated. I got message saying 'c' is available but the user account that you are logged on with...
If you are using Window's XP or later the problem is probably the account you are logged into doesn't have "administrative access". You will have to log into the administrative account to make network changes.
If you are running Vista the default administrative account is hidden. To access it do the following: First you’ll need to open a command prompt in administrator mode by right-clicking and choosing “Run as administrator” (or use the Ctrl+Shift+Enter shortcut from the search box)
Now type the following command :
net user administrator /active:yes
You should see a message that the command completed successfully. Log out, and you’ll now see the Administrator account as a choice. (Note that the screenshots are from Vista, but this works on Windows 7)
You’ll note that there’s no password for this account, so if you want to leave it enabled you should change the password.
Disable Built-in Administrator Account
Make sure you are logged on as your regular user account, and then open an administrator mode command prompt as above. Type the following command:
net user administrator /active:no
The administrator account will now be disabled, and shouldn’t show up on the login screen anymore.
Feb 05, 2010 | Computers & Internet
ADmin rights on Vista Home Basic
For vista
Open the control panel and select System and Maintenance.
Scroll to the bottom of the page and select Administrative Tools.
In the new window open Computer Management.
From there open System Tools.
Now open Local Users and Groups.
And finally open Users.
Right click on the account named Administrator and select Properties.
There is a series of tick boxes in the lower half of the properties window deselect the one saying Account Is Disabled.
Apply the changes and Log Off, there should now be 2 accounts in your log in screen, select administrator.
when you go to delete your old account it'll ask you if you want to save the documents and settings from it. say yes and copy the files from the folder into your new admin account.
Jul 17, 2008 | Computers & Internet
Having problems removing programmes keeps saying I need to be the admin which I should be ??
Yes, you have to have administrator rights to add/remove programs.
Log out and then log in as administrator:
First you must ensure that the Administrator Account is enabled:
1 open Control Panel
2 open Administrative Tools
3 open Local Security Policy
4 expand Local Policies
5 click on Security Options
6 ensure that Accounts: Administrator account status is enabled
2 open User Accounts
3 click Change the way users log on or log off
4 untick Use the Welcome Screen
5 click Apply Options
You will now be able to log on as Administrator in Normal Mode
Jul 17, 2008 | Packard Bell Computers & Internet
Konica Minolta Bizhub C300 All-In-One Printer Logo
276 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
carpediemweb
Level 1 Expert
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
