Computers & Internet Logo
jose oquendo Posted on Jan 31, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My lenovo ideacenter k330b ask me for a command or filename i have block sneen command or filename
I bown air to remove duet and tune it on and got a block sneen asking for a command or a filename also time and date
Joe Goldman
Level 2:
  • Expert 337 Answers
  • Posted on Jan 31, 2013
Joe Goldman
Expert
Level 2:
Answers
337
Questions
Helped
119064
Points
950
If you see "time & date not set", then you need to replace the bios battery on your motherboard.....this is the battery that keeps the time and date settings as well as all the hardware settings for the motherboard. It is a CR2032 button cell battery (see picture below) It sounds to me like the bios battery is dead and the motherboard has lost its config information about your hard drive. Replace the battery (about $5) and check the bios settings to ensure the hard drive is detected. If this doesn't fix it, or if you do not know your way around a bios, then consult a tech-savvy friend, or take it to a qualified technician.
Hope this Helps!!
-Joe
my lenovo ideacenter k330b ask me for a command or - 1_31_2013_9_08_49_pm.jpg
3 Related Answers
Anonymous
  • Posted on Mar 06, 2009
SOURCE: service partionin lenovo ideacenter k210 53131bq
i dont no help pliz
dominioni991
Dominion Computer Solutions, Inc.
  • 312 Answers
  • Posted on Aug 23, 2009
SOURCE: Lenovo Ideacenter K 210
Sounds like you have a connectivity problem. Can you get online?
Rodie
  • 629 Answers
  • Posted on Oct 07, 2010
SOURCE: when your labtop get wet
it would help if you can provide the exact message it gives you. if the laptop got wet, there is a chance that internal components like the motherboard may have already been affected/damaged and may need replacement. the exact message would give us more data on working on this one. However, if in case the message comes up when it already try to load Windows, try last known-good configuration, system restore or Windows reinstall. To try last known-good, shut down the laptop, remove its battery and AC adapter, press and hold down the power button for about 10 seconds, remove and reconnect the hard drive, then reconnect the adapter and battery, restart the computer, tap F8 a few times as it restart to get to the Advanced Options menu, then select Last Known-Good Configuration. If this does not work, go back to the Options menu, select Safe Mode and if it boots, try system restore, otherwise, reinstall Windows. Let us know how it goes.
Wont boot up.Turns itself off.
If you can startup in your bios start up with a linux live-cd/dvd or a usb pendrive if its booting correctly with linux then yoursystem havea problem to resolve by or the commercial lenovo software ?? but make use of a windows repair on the right driveletter a chkdsk command from microsoft software cd or from a hidden systemdrivepartition with a special command from Lenovo cd or a windows 7 tool command in a console use chkdsk /r chkdsk /u or chkdsk /p or other tools that you can anyway repair your boot.cfg or other tools.
If your pc was repaired change the boot priority to drive where your bootfile is on and is it booting again use allways a combofix program in any way over the disk to correct the system from heavy registery problems
http://www.bleepingcomputer.com/download/combofix
http://www.tweaking.com/content/page/windows_repair_all_in_one.html
Free PC cleaner
How do u replace CMOS battery in Lenovo ideacenter b305
you have 2 take it apart ma man some time they are under the keyboard or not to far from the ram but in most cases you have to open it
Lenovo IdeaCenter K300...turn power on, light comes on, turns off, and 2 seconds later comes on. Fans are running but nothing on screen
just unscrew the tower remove the RAM - erase the golden color edge with a pencil eraser and then place it back. make sure the RAM edge looks golden glittering new, wired solution but worked for many trust me
I want audio driver for XP of lenovo ideacenter K 210
The same model Ideacentercan have different types of network, video and audio drivers and unless youknow exactly which one is installed in your Ideacenter, you need to download allthe drivers and install each driver until you find the right driver. When you download thedrivers, write down the device driver and it's file name so you have a recordof which driver you are installing and which directory the unzipped files arelocated on your hard drive. Go to the IBM/Lenovo WEBsite - support/download page and download the latest Windows device drivers foryour model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Lenovo all in one ideacenter desktop series -3000c100, i forgot bios password pls help? [email protected]
To reset the BIOS read the information from this link.
In case of your laptop the easiest method would be using software from Hiren's Boot CD as it's pretty hard to open it up and reach for the CMOS battery or the jumper.
I have lenovo ideacenter kseries there is no video card driver i want video card driver what can i do for that
hi! you can actually download that for free you can actually go to this website so you can downlaod it. it is on consumersupport.lenovo.com
hope this helps! goodluck!
Grand Canyon Tech
Grand Canyon Tech
