Dell OptiPlex 170L PC Desktop Logo
Question about Dell OptiPlex 170L PC Desktop
My dell optiplex 170l it shows older time of 2005 when ever goes off, i tried to replace the cmos and i upgraded the bios version from A07 to A09 but still it has refused , it keeps going back to 2005 time , HELP
Posted by K-legacy Habab-nas on
Jose Diaz
  • Dell Master
  • 2,878 Answers
Replace CMOS battery. Change time in BIOS. Save.
Posted on Jan 31, 2013
4 Related Answers
Mark Rogers
  • 102 Answers
SOURCE: Optiplex Gx110 Freezing on Bios Post
The only thing I can think of is there should be a jumper pin that on the mother board that resets the cmos. Unplugging the battery does not clear the cmos rom. My guess would be the cmos rom is currupted and unfortunatly you need the rom loaded before you can flash and replace it. My advice is ditch it.
Posted on Aug 02, 2007
Anonymous
  • 837 Answers
SOURCE: Dell Optiplex 170L does not recognise an 80GB Hard Drive
Just for giggles try changing the boot order so that the C drive is first
Posted on Nov 23, 2008
Anonymous
  • 128 Answers
SOURCE: Dell Optiplex GX270 bios will not recognise
u will need to first update your bios and then reinstall dvd cdrw
Posted on Dec 04, 2009
Anonymous
  • 153 Answers
SOURCE: my Dell optiplex 170L keeps turining off and then
Possible that it's caused by a faulty hardware or a computer virus on your computer. For us to isolate the issue we must start troubleshooting with the hardware
1. Remove all the connection at the back of your computer
2. Power cycle your computer tower by pressing the power button for 15 seconds
3. Plug the power cord back in and monitor cable at the back of your computer tower (if it turned on, meaning that one of the device plugged at the back of your computer is the one's causing the problem, for you to pin point the problem, try plugging it one-by-one and turn on the computer each time you plug a device)
4. If it keeps on doing that, open up your computer tower (be careful to unplug the power cord and power cycle it to avoid static electricity)
5. Reseat the video card, turn on the computer again, if it's still occurring
6. Reseat the IDE/Sata cable of your hard drive and try to make sure it's properly plugged in, turn on the computer again, if it's still occurring
7. Reseat the memory, turn on the computer and test it again if the same thing
8. If you have 2 memory chip inserted in your computer tower memory slot, remove the other one and turn on the computer, do the same thing to other memory and each slot
9. If all else fails, restart the computer and keep on pressing F8 before the window welcome screen comes up - to go to advanced boot options
10. Boot to Safemode
11. If you are able to boot to Safemode
12. Login as administrator
13. Click start
14. run
15. type msconfig then press enter
16. click on startup tab and click on disable all button at the bottom part
17. Restart the computer and let it start normally
18. if the same thing happen, boot to safemode again
19. Login to administrator again
20. Right click my computer
21. Click on properties
22. Click on Advanced Tab
23. Click on settings button under Startup and Failure
24. Uncheck the Automatically restart under System failure
25. Restart the computer in normal mode
26. Tell us if you see any blue screen error, if so, post the error here
if all else fail, your operating system needed to be reinstalled and you should have the cd for the operating system if it's XP or Vista or Windows 7.
Posted on Jan 09, 2010
How can i do bios recovery in dell optiplex 170L
You should take out CMOS battery and wait for some time, replace it and BIOS should be reset to factory condition
I am trying to upgrade to a 1tb SATA HDD on my Dell Optiplex GX270. It does not recognise my new drive in my BIOS, I have updated BIOS to A07. Am I missing something? Is it compatable with SATA?
I have the same model PC with a 250gig Sata HDD and dont have any problems. If a PC can read 250g it should be able to read 1000g. This may sound silly but is Sata turned on in Bios
1helpful
My battery won't charge in my Dell E1705
The current bios version is A09. The bios version on your system can be found under the Dell splash screen when you first turn on your computer or by going into the bios itself. If your version is older (A08, A07, etc), you can go to http://www.dell.com and at the bottom click Drivers and Downloads. Get the 7-digit alphanumeric Service Tag form the bottom of the laptop and enter it when prompted. It will take you to the Download page specific to your computer where you can then download the current bios.
While some battery issues have been taken care of with a bios update, in my experience the issue is usually the battery itself not being able to hold the charge. On average batteries develop problems about a year to 2 years after purchasing the laptop, just in time for the warranty to run out. This means a new battery will need to be purchased. I have also run into the power adapter not charging the batter properly due to the the adapter failing or a break in the cord coming from the wall outlet or from the brick to the laptop. Verify that the power adapter is working properly.
BIOS failure ??? DEll Systems OptiPlex GX270 Series
this may or may not help, try taking out the cmos battery out (looks like a watch battery) and leave for a few minutes then replace, this will reset the bios.
2answers
2answers
Mehandi Husain ...
Steve Sweetleaf
Steve Sweetleaf
